Moebius Skipjack
    • 13997
    #256
    differentiate between 'different' and 'correct'!
    Scale modeling is the pursuit of perfection, and the rejection of deliberate false presentation. You either do it right (perfection being unattainable, but must be the standard that guides us), to the best of your ability, or you don't. And if your work falls short you hone your abilities, increase the level of your skills, and fix it!
    Never settle for good-enough!
    • Ken_NJ
      • Sep 2014
      • 1006
      #257
      Got it David!
      What's the beat way to handle these deadlights?
      Put the lens on, then the PE, mask off the lens, then paint? Tuff to mask off that clear lens.
      That PE is so thin. How to glue it without making a mess of the lens.
        • 13997
        #258
        Originally posted by Ken_NJ
        Got it David!
        Eazy-Peezy.
        1. CA the dead-light within the sail
        2. with a finger build up several layers of CA, the thickness of the CA a bit higher than the surrounding sail structure
        3. sand and polish the CA over-coat to an optically clear status
        4. scribe the outer perimeter of each dead-light to the outline and depth of the PE retaining flange
        5. apply white glue (bezel glue if you have it) sparingly within the outboard sides of the scribed trenches
        6. insert the flange and wipe away any glue that squirts out, wipe away from the dead-light
        7. mask the deadlights and paint
        8. sing my praises!
          • 3767
          #259
          Mask dead lights with white glue. Once painted, you can wash the white glue out.
          • Ken_NJ
            • Sep 2014
            • 1006
            #260
            Thanks David and Tom. Working on it.
            I knew that valley would be a problem. I did a decent job taping the perimeter, so I thought. How can I get these to appear better? Either you tape to the inside or the outside, but in both instances I thought they may not come out clean.
              • 13997
              #261
              Always mask so the engraved trenches get the darker color.
              • Ken_NJ
                • Sep 2014
                • 1006
                #262
                I should have checked with you before I taped it off. Now what?
                  • 13997
                  #263
                  Mask the buoy and touch up the perimeter with the same dark-gray as you used on the hull. Duh!
                  • Ken_NJ
                    • Sep 2014
                    • 1006
                    #264
                    What do you use here? For the mesh? I wandered HD and did not find anything suitable? Looks to be some sort of plastic strainer thingy.
                      • 13997
                      #265
                      In days of old, when AC was not the norm, we had this magic material that would keep bugs out and fresh-air in. It was called 'screen'. Back then it was metal mesh, today it's plastic, and easily pulled into compound curves. At your big-box store. Ask for, 'bug screen'. Sold by the roll.
                      • Ken_NJ
                        • Sep 2014
                        • 1006
                        #266
                        LOL, yea I buy a 10 yard roll for 6 square inches.
                        I do have some metal screen that I use to make diamond plate on another boat. Impregnated it with resin, came out great looking. But I think it's to fine for the submarines purpose.
                          • 13997
                          #267
                          I'll send you some screen. I'm the idiot who bought a whole roll of the stuff years ago. Email me your mailing address, Ken.
                          • Ken_NJ
                            • Sep 2014
                            • 1006
                            #268
                            LOL, will do, thanks David.
                            This should do as well. Needle point plastic sheet from the craft store. https://www.michaels.com/rug-canvas-.../10035953.html
                            • Ken_NJ
                              • Sep 2014
                              • 1006
                              #269
                              David, can you post a pictures of the masts. Working on airbrushing them. And did you get my email about the mesh?
                                • 13997
                                #270
                                Yeah, that needle-point mesh looks like it has utility.
                                I'm sending you plastic mesh sheets today. Look for them by mid-next-week.
                                Here are some shots of actual SKIPJACK boats as well as model SKIPJACK's I've assembled and built. With emphasis on the masts, fairings, optics, and antennas:
