Seaview
    Success! Now on to the second problem. The Polk receiver was on the list to be changed due to poor reception compared to the Sombras. Ive also noticed that the Seaviews servo, that controls the stern planes(which is hooked to the APC) would move back and forth on its own while the motors were running. WELL, GUESS WHAT???!!! With the Sombra in place, NO UNWANTED SERVO MOVEMENT!!! OUTSTANDING!!! I couldnt be happier with that! As the instructions that come with the Sombra says " the most advanced DSP signal detection, noise control, and glitch suppression algorithms". Best $64 I ever spent.........lately.
      It's this sort of comment that we really need posted on our web page.
      You can do that here! and earn points too!
        • 13948
        #93
        If I can expand on what Mark observed above:
        I have around fifteen working r/c submairnes, employing the entire range of SubDriver's. And ALL OF THEM were either assembled outright with a Sombra Labs receiver or were retro-fitted with one. I swear by these receivers. Polk's is second best in my opinion (not a slam, a well studied fact), but the Sombra product is absolutely the best receiver on the market for our needs.
          For those who are interested, here is a link to a more detailed builders thread on her.http://s181686668.onlinehome.us/phpB...t=6851&start=0
            Now that the Sombra is in place and the right hand drive is fixed, she is now "Secure For Sea". I got to get my camera man and get her to the pond by sundown for some Dusk pictures and Video.
              Another interesting fact about the Sombra verses Polk discussion is that the Sombra you can use it for either 72 MHZ or 75 MHZ. The Polk, you have to send back to them for them to reprogram. Just a little FYI.
                Found these pictures and I thought that I might post them.
ID:	67912Click image for larger version
ID:	67913Click image for larger version
ID:	67914Here we are with the sail planes set to surface thru thick ice. Hey , the Typhoon isnt the only game in town............ALL AHEAD FLANK!!!
Name:	Seaview at Devils den broad zoom.jpg
ID:	73008Click image for larger version
ID:	73009Click image for larger version
Name:	Seaview rear quarter.jpg
ID:	73010Click image for larger version
                    • 13948
                    #99
                    Beutiful! I still owe you a 3" SD, I have not forgotten .... gotta get out from under all this SKIPJACK master making work
ID:	73012Click image for larger version
ID:	73013Click image for larger version
ID:	73014Click image for larger version
ID:	73015Click image for larger version
ID:	73016Click image for larger version
ID:	73017Click image for larger version
ID:	73018Click image for larger version
ID:	73019Click image for larger version
ID:	73020Click image for larger version
ID:	73021Click image for larger version
                      Dave, that is beautiful stuff, dont know how you do it.
                        • 13948
                        #101
                        Simple:
                        I'm extraordinarily talented, my poop don't stink, and Ellie holds the leash tight when I'm in public.
                        You ain't half-bad yourself, Mark.
                          Just a couple of enhanced pictures that I wanted to Post. Shes definitely leaning to port slightly. Gotta address that.
Name:	Seaview shallow close.jpg
ID:	74916Click image for larger version
Name:	Seaview even closer.jpg
ID:	74917Click image for larger version
                            • 3735
                            #103
                            How do you secure your battery? Are you using LiPos? I ask because I had to secure my battery to keep it from shifting. One day it would lean to port the other starboard.
                              Good point. I have a battery WTC that fits tightly so that it cant move. I bought a new LIPO with more capacity. It weighs more than the other one so I have to add more foam anyway so I can solve both problems at the same time.
                                • 3735
                                #105
                                You got it handled! I like the way the Seaview looks in the water and great photography too!
