    • 13937
    #241
    today's work:
ID:	76869Click image for larger version
ID:	76870Click image for larger version
ID:	76871Click image for larger version
ID:	76872Click image for larger version
ID:	76873Click image for larger version
ID:	76874Click image for larger version
ID:	76875Click image for larger version
ID:	76876Click image for larger version
ID:	76877Click image for larger version
ID:	76878Click image for larger version
ID:	76879Click image for larger version
      • 13937
      #242
      Ever since Romel got me to make the kit adaptable as a camera platform I was stuck on the problem on how to hold the removable line-locker door in place -- doing so in such a way that did not ruin the scale 'look' and was also easy to achieve. Magnets to the rescue!
      The circular strong-back on the inside of the sail jams into the taper that transitions into the circular flange on which the line-locker door seats. Put a magnet in the center of the strong-back, put a magnet in the center of the doors inboard side, and you're in business!
      When using the video camera-transmitter you take the strong-back and line-locker door and put them in safe storage so the camera can shoot through the resulting hole. Operate without the camera-transmitter and you make up the strong-back and line-locker door. Simple
ID:	76889Click image for larger version
ID:	76890Click image for larger version
      So, when Ellie does not have me playing Plumber, I'm claying up the Bronco 1/35 Type-23 fittings kit masters. I'll finish that work tomorrow. Rubber should be in by Friday and I want to be ready for that.
ID:	76892Click image for larger version
ID:	76893Click image for larger version
ID:	76894Click image for larger version
ID:	76895Click image for larger version
ID:	76896Click image for larger version
ID:	76897Click image for larger version
ID:	76898Click image for larger version
ID:	76899Click image for larger version
      And I'm working up a 1/35 'generic' figure. From that tool I'll cast up a bunch of blanks -- those little figures will be dismembered, reassembled, and detailed to represent a proper bridge crew at work up high in the sail. Time permitting, some deck-hands.
      • ffr2608
        • Oct 2009
        • 341
        #243
        Looks great Dave. Didn't the 23 have a 4 blader?????????Swearing Smiley
        Darrin
          • 13937
          #244
          OH, GOD!!! You'll never let me live this down, will you?
          For those looking over our shoulders: That's Darrin Hataway -- one of the finest model builders I know. He's referring to the propeller I made for us to drive his excellent kit of the UDT/SEAL delivery vehicle, the MK-8. Damned thing is I read the documentation wrong and supplied propellers of the wrong blade count. I'm such a dope sometimes!
          Darrin's done a lot of master work for OTW and others. He's a professional at this game and is not to be messed with!
          • ffr2608
            • Oct 2009
            • 341
            #245
            Last time...I promise. I really like the amount of details you are providing on this kit. As most know, the type 23 in this scale is one of the best all around boats. Easy to transport, excellent handling and still a ton of available detail. Nice work as usual Dave and thanks for the kind words.
            D
              • 13937
              #246
              D
              Any time, Darrin ... I dish it out, and I can take it too. You know that. Please, post here anytime -- and please share with us your work, pal.
                • 13937
                #247
                While awaiting the big order of mold making rubber from BJB, I took what was left here to make the metal casting tools for the propeller and bell-cranks, and the tool needed to cast up a bunch of resin 1/35 U-boat crew figures -- from those castings I would individualize each in either in the winter officer or enlisted garb appropriate for a late war German submarine crew. Once I have a hand-full of Type-23 ruffian's I'll use those to make the final crew production tool.
ID:	76906Click image for larger version
ID:	76907Click image for larger version
                As an example of the figure work yet to be done on the blanks, I submit these shots of the work I did in support of the aborted 1/72 FOXTROT effort. Gotta tell ya: it's a lot easier working 1/35 figure masters than 1/72!!!
ID:	76909Click image for larger version
ID:	76910Click image for larger version
ID:	76911Click image for larger version
                With all the major surgery done on the hull time had come to rebuild the weld-lines lost to file and sandpaper and I cleaned up the split between upper and lower hull. The weld-lines were built up of air-dry touch-up putty and the big 'bricks' near the stern formed from a two-part automotive filler followed by some careful work with knife, file, and sanding squares.
ID:	76913Click image for larger version
ID:	76914Click image for larger version
ID:	76915Click image for larger version
ID:	76916Click image for larger version
ID:	76917Click image for larger version
ID:	76918Click image for larger version
ID:	76919Click image for larger version
ID:	76920Click image for larger version
                In the gap between the 'bricks' can be seen a short length of weld-line. I'll likely re-establish those like what I did on the 1/12 KAIRYOU:
ID:	76922Click image for larger version
ID:	76923Click image for larger version
                  • 1639
                  #248
                  Blimey David,
                  I 'm loosing it, you even have two boats accourding to the pics, i ordered a bunch of stuff from the shop, it will pay your salary for this month, i'm financially ruined!!!!!!!!!, thanks.
                    • 13937
                    #249
                    Bewewhohaaaaa!
                      • 2615
                      #250
                      I was trying to think what that little red guy in the conning tower reminded me of, then I remembered.
                        • 13937
                        #251
                        [ATTACH=CONFIG]19698[/ATTACH]
                        "Andy Lawrence, ladies and gentelmen! He'll be here all week ... try the veal"
                        (smart-ass Brit')
                          • 13937
                          #252
                          Though the BJB TC-5040 silicon mold-making rubber is not advertised for high-temperature work, I find, in a pinch (when I run out of TC-5050), that it will work fine with white-metal work. This evening I made some test shots with the tools, and they are holding up just fine.
                          Now to make some holding fixtures for the bell-cranks so I can drill and tap their set-screw holes. Time permitting I'll shape the propeller dunce-caps, bore and tap the set-screw holes, and work out how the production propeller shaft and bearings will go. Another long night/early morning ahead of me ...
ID:	76926Click image for larger version
ID:	76927Click image for larger version
ID:	76928Click image for larger version
ID:	76929Click image for larger version
ID:	76930Click image for larger version
                            • 3664
                            #253
                            Hey David. Along with the camera in the conning tower why not make another part of the kit functional- the Balkon Gerat. Maybe fit one of those wireless fish finders inside the bow http://luckyproducts.en.made-in-chin...r-FFW718-.html
                              • 1639
                              #254
                              Bewewhohaaaaa!
                              Boy, i desperately need a sinkhole.
                                • 13937
                                #255
                                Hey! Romel! I've got a great idea!!!! .... why don't I stick a broom-handle ******** so I can sweep the place out as I work??!!!!
