New Toy For The Swimming Pool
    • 13838
    Single pump- dual output. Diverter valve for differential thrust. Click image for larger version Name:	FB_IMG_1731326319972.jpg Views:	0 Size:	68.3 KB ID:	184036
    THAT!... is slick!
      • 3621
      THAT!... is slick!
      Some more Click image for larger version
ID:	184069 Click image for larger version
      Click image for larger version  Name:	Screenshot_20241029_225029_Samsung Notes.jpg Views:	0 Size:	58.9 KB ID:	184067............
      • Rick Teskey
        • Jan 2009
        • 265
        What size is twin nozzel output dia.?*
          • 2016
          I like! Might be a good solution for bow thrusters.
            • Oct 2017
            • 1016
            Good to see you keep going, Rob! So your health got better? I hope so! Always impressed of how busy you are! Thumbs up!
            Jörg
              • 3621
              Have you done a tub test?
              IMHO the duct needs to be longer with a gradual bend not 45°. Also the gill slits need to be angled more so as not to restrict flow.
                • 3621
ID:	184178 Maybe use a hairdryer to open up the gill slits some more...
                  • 3621
                  If does not work, I sure will have an interesting model...
                  • Rick Teskey
                    • Jan 2009
                    • 265
                    What program do you design in?
                      • Oct 2017
                      • 1016
                      My best guess its JAWS. Creator's edition.
                        • 3621
                        Rob, What I meant was, if it doesn't work you could make a wall mounted plaque of the head. X-D
                          • 3621
                          How bout this Click image for larger version
                          3D file available
                          https://www.cgtrader.com/3d-print-mo...er-scale-model
                            • 13838
                            A very good effort, Rob. We all profited from your successes and well documented blunders -- there are lessons in both good and bad results of one's efforts while 'pushing the envelop'. You have the curage and confidence in yourself to deliver the bad as well as the good news. I like that! I'll drink beer with you anytime, pal.
                            Keep fighting the good battle, Ron. You fire eating, SCUBA mud sucking, whack doodle, robot making mad-scientist, you.
                              • 3713
                              You shared ideas that others may be able to use. I am bummed you are not moving forward, but I get the burned out feeling. Thank you.
                              Look forward to when you may start your next project.
                              • Rick Teskey
                                • Jan 2009
                                • 265
                                #30
                                Knock out the gills all together that might give the thrust needed
