New Toy For The Swimming Pool
    Today I am making more head way on the two WTC (boxes) electrical.
Name:	SHARK BUILD 56.jpg
Name:	SHARK BUILD 57.jpg
    I have installed the water tight connectors for the power suppy from the battery box to the electronics box.
    "Firemen can stand the heat."
      Seems like when the building process starts to move in the right direction it is hard to stop working on it.
Name:	SHARK BUILD 58.jpg
      I now have all the external wiring penetrations needed for the WTC (watertight boxes) what's remaining is the two 3s 11.1 volt 2200 mah (wired in parallel) in #1 box and the #2 box will contain the two ESC's, one receiver and the corresponding wiring required. The receiver antenna will exit the #2 box and run through the 2 main body interiors.
      As an explanation as to what the wires are. The two large black cables contain the wiring for each of the two thrusters. Each cable contains 3 16 AWG wires that will connect to the 3 16 AWG wires from the thrusters. the red and black silicone wires are the 14 AWG wires that are coming from the battery case to the electronics case. I allowed extra length on those two wires which will allow to remove the battery case and remove the Lipo batteries for charging.
        This morning in 38 deg water I did a leak test on my 2 watertight boxes.
Name:	SHARK BUILD 59.jpg
        Held them under in about 18" of water for 3 to 4 min using my leaf collector handle. Here to say not a drop of water inside the boxes.
        I am now ready to complete the interior wiring process.
          At this point of the main hull build I glued up the 2nd main hull member to the main tail section.
Name:	SHARK BUILD 60.jpg
Name:	SHARK BUILD 61.jpg
          I also did some sanding and some fill in work. The main hull sections are completed, the head mounting system is complete. Ounce I get the wiring completed in the two boxes I will be able to install and connect up the thrusters.
          "Firemen can stand the heat.".
            Finished up the electronics wiring inside the WTC (watertight box)
Name:	SHARK BUILD 62.jpg
Name:	SHARK BUILD 63.jpg
            I also installed my FM receiver in the watertight box and I will be running the antenna inside the two main hull sections making a loop. I got this VEX transmitter and receiver from Nautilus Drydocks that I did not use on a 212 build. I am going to set up the throttle stick and the dive plane stick and make it a manual two stick operation. I have already bench tested it and it is going to work ok.
              Here is the arm and hand mechanics I used on my InMoov Robot.
              Quite complicated and tedious work to say the least, I loved every min. of this Robot build...
              This YouTube is in reference to Romels YouTube on page one of this build blog showing the mechanical arm. A little off course from my shark build..
                I am starting to work on the two lateral fins.
                Click image for larger version  Name:	SHARK BUILD 64.jpg Views:	0 Size:	55.4 KB ID:	185637
                I have installed weights inside the two fins for ballast weight and then filled with some epoxy resin to hold them in place. I had thought about adding the weight to the bottom hatch, then beings the fines where basically hollow why not put the weigh down even lower and very close to the CG on this shark. We will certainly find out when we start water testing this beast..
                  Today was spent finishing up all the wiring on my shark!
Name:	SHARK BUILD 68.jpg
Name:	SHARK BUILD 69.jpg
Name:	SHARK BUILD 70.jpg
                  To finish it up the only thing that was left where the thrusters. I wired in waterproof disconnects to each thruster to make replacement or repairs much easier.
                  All control wiring, receiver and transmitter are set up. I did do a bench run to make sure all the wiring was correct and both thrusters worked in the correct direction.
                  I will be doing a complete water check (in the pool) on everything to be sure there are no leaks in either of the boxes, and then I will do a run up in the pool to check out the thruster operation. If everything checks out, I will go back into completing the sharks body build, adding weight and foam as required. And then more pool testing before the final finish work.
                    OK!
                    I am sorry this video is a little wild. I did not realize that the shark was about to pull out of my hands. But as you can see the thrusters are working great and with some real force.
                    I also realize this run was just the thruster housing ONLY, I hope when the head and the rest of the tail section are installed that I can get enough water into the thrusters to get some good forward operation. Based on my trail run its going to work out.
                      Today I cut, fit, and glued in the floatation foam for the shark.
Name:	SHARK BUILD 75.jpg
Name:	SHARK BUILD 71.jpg
Name:	SHARK BUILD 74.jpg
                      I also fabricated the sharks stand. The brackets where 3D printed and will be mounted to painted piece of wood. This will certainly make the shark a lot easier to work on and to lend itself to a model stand as well when the shark is not in use.
Name:	SHARK BUILD 73.jpg
                      Tomorrow I will be mounting the lateral fins and the dorsal fin to the main body. After that is completed, I will mount the tail section, install the electronic boxes, charge the batteries, and them it will head to the pool for testing. I am hoping that I will not have to deal with to much weight or foam addition. (Yes, that will be the day)
                        Finished putting the shark together to make ready for sea trails.
Name:	SHARK BUILD 72.jpg
                        Tomorrow, I will be putting it into the pool to find out how far off if any the trim might be. As stated, before in the build blog the added weight for ballast is built into the two lateral fins. I currently have the lighter of the two fins mounted. I built a set of two additional fins that are somewhat heavier if I need it. And possible additional weight required will be built into the hatch cover. I also have addition space at the top of the shark for foam if needed.
                        "Firemen Can stand the heat.
                          Starting the prep work to get the shark ready for its maiden voyage. The way I have it set up currently, the Vex transmitter will be turned on and then I will plug the two 11.1 volt 2200 lipo batteries into the parallel connector, place the battery box inside the shark and close up the bottom hatchand head for the pool.
Name:	SHARK BUILD 77.jpg
                          I realize the way I have it set up right now is a real pain in the butt. And I would agree. If the testing goes well today I will be installing a remote switch system for future pool operations
                          My wife is going to do a series of videos as to how it all works out. It will either be a real Laurel and Hardy show or (I am hoping) a really nice operational pool shark!? At this point we are waiting for the outside temp. to get up to 65 deg. I will need to step into the pool to launch the shark, no way I can just kneel down and slip it over the side. The old bones just won't allow that. Ha Ha.
                            • 1393
                            #73
                            That shark looks good....curious to see how it performs. But definitely suitable to scare some folks in the pond....
                              Thank you, Andreas
                              But the testing did not go as per plan... The trim was way off so I need to adjust by taking some of the foam out of the head or may be add some weight.
                              I also had an issue with the motor operation which I attribute to a slight leak in the electronic box. I really do not enjoy showing my failures that much, but to me I think you need to show the problems that can arise from these projects, and to me that is certainly part of the learning process. This shark will be a performer when I get the issues ironed out...
                                One of the issues that I found with my electronic box was I had a leak. I got somewhat fancy with the wiring exists and my idea seemed to fail. So, I have ordered up another box and will use better components than the handmade leakers that I built.
                                I do have a question:
Name:	SHARK BUILD 76.jpg
                                The above photos show the shrink tubing on my soldered wire connections. Is heat shrink waterproof if done properly?
                                The bottom photo shows the waterproof wire connectors that where soldered to the thruster motors and these connections are exposed to water.
