today's work
    • 1552
    #2491
    I've mailed my adres, but forgot to ad Noord Holland in it, let's see if i can do some good work in the future for the kriegsmarine in europe
    Manfred
      • 13750
      #2492
      Manfred
      The Game is Afoot!
        • 13750
        #2493
        Manfred
        Next stop: Holland!
        Toy Maker of Note
          • 1552
          #2494
          So i have to hurry up with Spirou sub, before i know it my plate will be full
            • 13750
            #2495
              • 3564
              #2496
              Does one need to cover the positive terminal in rtv silicone to prevent corrosion?
              3rd bolt for fixing the wtc in place?
                • 13750
                #2497
                antenna stud
                  • Oct 2017
                  • 1007
                  #2498
                  So this boat is still on trial (Yellow stripes)!
                  Representing a particular boat number?
                  • DrSchmidt
                    • Apr 2014
                    • 1347
                    #2499
                    Yellow stripes = school boat
                      • 13750
                      #2500
                        • 3564
                        #2501
                        Click image for larger version  Name:	XiBvnJ.webp Views:	0 Size:	106.6 KB ID:	183417 Can this particular 2" WTC be used in the 1/144 Trumpeter Xia class SSBN, Seawolf or Astute class?
                          • 13750
                          #2502
                          I suppose so, with an appropriately sized ballast tank
                            • 3564
                            #2503
                            You mentioned the ballast section for the XXI is around 3.75 ounces (110ml). What's the estimated ballast tank volume of the Xia class?
                              • 3689
                              #2504
                              Are you expecting the Type XXI to be at waterline with that size tank? (I am not saying it won't, it looks small)
                              Tom
                                • 13750
                                #2505
                                Tom
                                It is small, but enough for that model. During the hull layup I went with three laminates of ten-ouch cloth for the lower hull and only two layers for the upper hull. That resulted in a much less dense above waterline structure than that below. Including the hollow cast sail the above waterline structure represented only a bit over three ounces of water displacement. That's all this models ballast tank has to hold to destroy the reserve buoyancy needed to unfloat the boat.
                                Click image for larger version  Name:	IMG_0167.jpg Views:	0 Size:	47.6 KB ID:	183427
                                Click image for larger version  Name:	IMG_0128.jpg Views:	0 Size:	54.4 KB ID:	183428
