today's work
    • 13608
    #2236
      • 3449
      #2237
      Will you also be trying a single motor with gear splitter set-up?
        • 13608
        #2238
        Nope....................
          • 13608
          #2239
            • 3449
            #2240
            Waterproof motor box? Click image for larger version
ID:	181025 Click image for larger version
              • 13608
              #2241
              Nope. In the wet.
              • bwi 971
                • Jan 2015
                • 940
                #2242
                Thinned the air dry putty to paint it on and then sand it down?
                Grtz,
                Bart
                "Samuel Smiles"
                  • 13608
                  #2243
                  Grtz,
                  Bart
                  Yupe......
                    • 3449
                    #2244
                    Click image for larger version  Name:	Screenshot_20240628_083734_Chrome.jpg Views:	0 Size:	49.0 KB ID:	181050
                    not a lot of space in the stern for linkages.
                    thinking you're going with differential motor steering and operational front planes only
                      • 3449
                      #2245
                      6-14v dual brushed motor esc for RC tanks
                        • 13608
                        #2246
                        No such thing as differential steering with varied propeller thrust on this design -- the nexus point of the two shaft forces is so close to the actual boats c.g. that the only effect was a slight crab -- a lateral motion -- instead of the desired yaw motion.
                        On the actual boats, that nexus point was aft of the c.g., so what very little yaw differential thrust produced was ass-backwards to the norm. Conning one of these beasts within the breakwater must have been a total *****.
                        Study the toe-in of the Type-21 shafts and think it through, pal. Nice ESC you've dug up on the internet, but useless on this submarine.
                        The two motors will be wired in parallel, and one ESC will do all the work. KISS.
                        Rudder, stern planes, and bow planes will be practical... as usual.
                          • 3449
                          #2247
                          in this case
                          bring out the watchmaker loupe
                            • 13608
                            #2248
                            • ffr2608
                              • Oct 2009
                              • 330
                              #2249
                              Looks great Dave. The real type 21 must have had some shallow angle gearboxes to couple the motors.
                              DH
                                • 13608
                                #2250
                                DH
                                The two shafts were not coupled, they worked independently. An experienced boat-driver could work out the 'Chinese' differential thrust situation unique to the class and use it to advantage when maneuvering in and out of pier.
