today's work
    • 13528
    #2176
    • Davjacva
      • Nov 2022
      • 399
      #2177
      Damn, that's a lot of BJB!!!
        • 13528
        #2178
        Yeah. Imagine if I had not put those displacing hunks into the flasks beforehand!
          • 673
          #2179
          So you insert the prop shafts before molding and I assume they are coated with a separator, so they twist free and turn when the casting is taken out of the mold? Or the shafts just rod as part of the casting process with slightly larger diameter & removed after to repeat on other castings - the channel is slightly larger for the actual prop shafts?
          Click image for larger version  Name:	qozeIi1.jpg Views:	0 Size:	46.4 KB ID:	180363
          • Rick Teskey
            • Jan 2009
            • 265
            #2180
            Why did you decide way back when (skip jack?) and presently on making stern sections out of cast resin you may have said in the past and I have forgotten or nobody listens to you anyway..?
            Could same tool be used ,not the inner displacement plug just the outer skin for grp layup or would cross section be too thin too retain shape?
            just kidding about not listening....Zzzzzzzzz
              • 13528
              #2181
              No. What you see are SS rods that form cores to produce the bores in which brass tube stern tubes (that accommodate the propeller shafts) will later be inserted and glued within the cast resin tail-cone. Once the casting cures, I yank out the SS rods and disassemble the tool quadrants to free the casting. I'll be done with the test shots of sail and tail-cone within the hour... stand by!
                • 13528
                #2182
                Ellie and I were 'production' guys; we employed materials and methods that balanced suitability of material to time taken to produce the product. Time is money. (Sometimes she would quip on the phone, to a casual caller: "We're busy making money here... keep it short!". The perfect gatekeeper).
                The involved and tight geometry of sail and tail-cone made hollow-casting the production process of choice, though GRP layup would have rendered much stronger structures. Yes, I have on rare occasions done glass layup within resin casting tools, with success, but doing so with such deep draft and tight radius forms requires plenty of gel-coat, followed by light-weight glass, backed up with heavier weave glass -- all very time consuming, but producing exceptionally strong parts, but parts that take forever to produce.
                D&E Miniatures started as a resin casting service -- we played to that strength throughout our run.
                  • 3409
                  #2183
                  Can you incorporate the stern tubes during the casting process? Would having them in place cause problems extracting the casting from the mold?
                  To prevent resin from entering and blocking the tubes it could be filled with beeswax.
                    • 13528
                    #2184
                    So. That's an idea. Show me how please. Meanwhile I'll just putter away with my awful attempts.
                      • 1520
                      #2185
                      Will the thinness of the shaft space cause problems with running screws? It may be just a bad camera angle I’m seeing. Very nice project.
                        • 3409
                        #2186
                        Who does one have to blow to get one of these?
                          • 13528
                          #2187
                          No problem. The installed stern tubes reside in the solid horizontal stabilizers which have more than enough beef to keep the shafts from wiggling.
                          This shot of the stern tube core piece -- a length of SS (two of them) -- residing within the cavity that will give form to the stabilizer once the pour is made will be completely encapsulated in resin. Very stout foundation.
                          • Rick Teskey
                            • Jan 2009
                            • 265
                            #2188
                            Thank you
                            looks like an 8 window on back wall behind Ellie
                              • 13528
                              #2189
                              Thank you
                              One of yours, maybe?
                                • 13528
                                #2190
