today's work
    • 1660
    #2161
    That will be a nice XXI David, getting steeringrods hidden away is a challence, those boats have even on a bigger scale problems with that.
    There are still some idiots who think that building a smalll boat is as easy building a big one, believe me, it's not.
    I tackled the seehund, but that is my limit in building mini subs
    Manfred
      • 14013
      #2162
      Manfred
      Let's face it Manfred, we're both Certifiable. But I'm just run-of-the-mill crazy. You. You, on the other hand, are pure 'Silence Of The Lamb's' crazy!!! Those little boats of yours stand as stunning proof of that.
      Fellow Whack-Job
        • 14013
        #2163
        Like Clockwork
          • 14013
          #2164
            • 14013
            #2165
            URL]
              Are you using the foam to reduce the amount of rubber required for the tool, or as a means to increase stiffness in the mould?
                • 14013
                #2167
                Both. The displacing foam helps to ensure proper registration of the rubber elements within the flask when preparing for a pour. This will become apparent come the next couple of installments.
                  • 14013
                  #2168
                    Slush casting?
                      • 14013
                      #2170
                      Slush casting?
                      No. Though without a core -- as the tools appear to be at this point of construction -- slush casting or GRP layup would be the only way to achieve a hollow part. But I'm not finished with the tools yet, the next operation is to form a core that will produce hollow parts. That process should be completed today. Casting of the first parts tomorrow.
                      Here are some examples of RTV rubber tools that employ a core:
                        Masterclass on molding and casting complex parts. I love it!
                          Still go into the pot for pressure curing?
                            • 14013
                            #2173
                            Yup. Details on that process to follow...
                              incorporate prop tubes in the horizontal stabs during final casting?
                                • 14013
                                #2175
                                Stay tuned... same bat-time, same bat-channel.
