today's work
    • 2759
    Henrique Alvim Corrêa's drawing of the Martian Tripod from H.G. Well's War of the World.
      • 12340
      Indeed. Of all the different illustrators of the many re-prints of Well's book, Correa's concepts were his favorites.
      • Ken_NJ
        • Sep 2014
        • 774
        You look like the kid in the candy store. Geeze thats an old expression.
        How much did that sheet set you back? Was that a lifetime supply?
        Stuff does not look cheap these days.
          • 12340
          https://www.amazon.com/Renshape-Mode.../dp/B0B5BBLR1R
          Yeah. I love that stuff -- beats the **** out of patten making woods. Ellie hated it, created a house full of fine dust -- but she came around a bit when she found it easy to sculpt (the 20 lbs. stuff, anyway).
          That 'log' came in at around $1200 plus shipping. The client (MIT School of Engineering Dept.) paid for it. I only used a small portion of it for the initial job. Yup, will still have plenty left over once I become worm-dirt.
          • goshawk823
            • Oct 2010
            • 212
            Thanks David. I knew back in the day people (you and Dennis come to mind) were using it, but i wasn’t sure if it’s just being used as a material from which you would cast finished parts (a master) or if it’s good enough material to actually use as a part.
              • 12340
              Both the dense and not-so-dense versions of RenShape find utility both as masters -- from which tools are struck -- and parts of the model proper. For example, that Martian War Machine I'm building is mostly fabricated from both types of RenShape.
                • 12340
                • ffr2608
                  • Oct 2009
                  • 239
                  Dave,
                  You should bring that sample hull with all the paint tests to Subfest. Would be great for people to see.
                  Darrin
                    • 12340
                    Originally posted by ffr2608
                    Dave,
                    Darrin
                    Not only that, but I'll lay out an array of picture binders as well as a selection of weathering mediums and tools. If table-space permits.
                      • 12340
                        • 12340
                        • Ken_NJ
                          • Sep 2014
                          • 774
                          What material are using for those decals? They appear to have a sticky backing to them? The vinyl decals that Callie Graphics has made for me in the past were self stick after the backing was removed. Whatever it is that you are using, ever had a problem with them curling up or getting upset after the clear coat was applied? Or over time?
                            • 12340
                              • 12340
                                • 1164
                                I’m really jealous of your ability to get your vents perfectly square.
