today's work
    • 2450
    #1591
      • 1936
      #1592
      Instead of 'sweet-talk', meaningless pap, and the typical 'it's all good' bull-**** others will salve you with, I'll give it to your straight, without varnish.
      Clarity is a virtue. The real world is indeed black/white; yes/no; true/false; and right/wrong. There is no maybe. There is no try. There are no multiple solutions to a specific problem.
      Absolutes are never achieved but should be strived for. Anything else is the road to chaos (hello, 2023).
      That thing is a kids toy. Learn from it what you can, and when you're ready, spring for a big-boy toy.
      Micro Lathe II Archives - TAIG Tools
      CENTRAL MACHINERY MINI LATHE MODEL 93212 7 INCH X 10 INCH 120V 60 HZ 3/4 HP | eBay
      Thank you David!
      I got it! I am for sure going to step up to MUCH better metal working lathe. Thank you for the web site listening's!
      "Firemen can stand the heat."
        • 13524
        #1593
        Thank you David!
        You'll have a blast. I've been pooping out shaving for nearly a half-century, and I'm still learning things on that and other machines. Much good fun... keep the band-aids at hand.
          • 13524
          #1594
            • 3409
            #1595
            Any update on the Chinese Type 092 SSBN?
              • 13524
              #1596
              It's near the bottom of the queue.
                • 3409
                #1597
                How about the 1/96 Type XXI?
                  • 13524
                  #1598
                    • 3409
                    #1599
                    Looks like the knife slipped.
                      • 13524
                      #1600
                        • 1936
                        #1601
                        These pages showing your choice of different finishes is really interesting. Especially the water based acrylics, and the assorted brushes. Don't know if you remember or not, but you walked me through the process of using the acrylics on my H L Hunley finish work and especially using sponges to apply the colors. (I even got a sort of a job well done) So I will be using the same techniques to finish out my ICTINEO!
                        • Ken_NJ
                          • Sep 2014
                          • 977
                          #1602
                          Airbrushing, yea did it. Learned enough from 'Today's work' and other David posts to get it done on a sub. Have to practice more, and more, etc.
                          Brush weathering. Did it. Have to practice much more.
                          Color wheel, got it. That FSC 595 chart, elusive, hard to find, ridiculously expensive from here.... https://ams-std-595-color.com/ Can find the colors online plenty of places.
                          Acrylic paints. Got the primary and a few others. Not good at playing mix my own colors.
                          Masking, yea did it. Could always use more practice.
                          Pastel chalk and oil paints. Have them but have not used them yet.
                          Weathering in general. Practice x1000.
                          Did the scribing thing years ago on the Marlin. Check
                          Built two submarines (need to build more) Check
                          Practiced airbrushing and AWL weathering on a test article. Check
                          Weathered a model submarine. Check
                          Using a lathe more often. Exciting work in progress.
                          Great resource here to learn!! Get er done!!
                            • 13524
                            #1603
                            Its guys like you two bum's who make it all worthwhile; seeing people such as yourselves take the ball and run with it is most satisfying to me!
                            Enough happy-talk... BACK TO WORK!
                            Task Master
                              • 13524
                              #1604
                                • 13524
                                #1605
