today's work
    • 1156
    This is cranking 10 pounds of @$&t into a 2 pound bag. Impressive.
      • 2759
      Would the 2" Subdriver meant for the 1/144 Seawolf have sufficient ballast tank volume to float her to scale water line?
        • 12317
        Don't know yet.
        How's that 1/144 KILO coming along? Finish it yet? Its been what?... TEN ****ING YEARS!!!!!!
        Inquisitor Extraordinaire
          • 12317
            • 1156
            Get a haircut.
              • 1156
              I’ve seen that boat in person. Amazing work.
                • 12317
                Originally posted by Das Boot
                Get a haircut.
                Bite me!......
                  • 3547
                  Bite me!......
                  Or a more David response.....(recently taken at SubFest 2022)
                    • 12317
                    Yup. That works too.
                    The Horrible
                      • 1156
                      He didn’t catch me.
                        • 2759
                        Looks like Dave working on Bob's 1/96 Blueback either before or after the tail got sheared off.
                          • 2759
                          Don't know yet.
                          Good to know your memory is still sharp.
                            • 1156
                            Mine suffered damage too when a novice ran it. One vertical stabilizer is still in need of repair.
                              • 12317
                                • 2759
                                Let's see if I got this correct.
                                To determine the volume of the ballast tank needed for your Nautilus you first weigh everything that's above the water line when the boat is surfaced. You then get a length of polycarbonate tubing set it on the scale, tare it to zero then slowly fill it with water until the weight of the water matches the weight of the above waterline items. You mark out the water level in the tube giving you the length of the ballast tank needed. Maybe add 10-15% margin to account for the items that go inside the tank like linkages, gas bottle, SAS float.
