today's work
    • 1600
    #1471
    This is cranking 10 pounds of @$&t into a 2 pound bag. Impressive.
      • 3560
      #1472
      Would the 2" Subdriver meant for the 1/144 Seawolf have sufficient ballast tank volume to float her to scale water line?
        • 13744
        #1473
        Don't know yet.
        How's that 1/144 KILO coming along? Finish it yet? Its been what?... TEN ****ING YEARS!!!!!!
        Inquisitor Extraordinaire
          • 13744
          #1474
            • 1600
            #1475
            Get a haircut.
              • 1600
              #1476
              I’ve seen that boat in person. Amazing work.
                • 13744
                #1477
                Originally posted by Das Boot
                Get a haircut.
                Bite me!......
                  • 3687
                  #1478
                  Bite me!......
                  Or a more David response.....(recently taken at SubFest 2022)
                    • 13744
                    #1479
                    Yup. That works too.
                    The Horrible
                      • 1600
                      #1480
                      He didn’t catch me.
                        • 3560
                        #1481
                        Looks like Dave working on Bob's 1/96 Blueback either before or after the tail got sheared off.
                          • 3560
                          #1482
                          Don't know yet.
                          Good to know your memory is still sharp.
                            • 1600
                            #1483
                            Mine suffered damage too when a novice ran it. One vertical stabilizer is still in need of repair.
                              • 13744
                              #1484
                                • 3560
                                #1485
                                Let's see if I got this correct.
                                To determine the volume of the ballast tank needed for your Nautilus you first weigh everything that's above the water line when the boat is surfaced. You then get a length of polycarbonate tubing set it on the scale, tare it to zero then slowly fill it with water until the weight of the water matches the weight of the above waterline items. You mark out the water level in the tube giving you the length of the ballast tank needed. Maybe add 10-15% margin to account for the items that go inside the tank like linkages, gas bottle, SAS float.
