Daily submarine picture
This is a sticky topic.
    Thanks PeterW. Do you see what I see? Look at the deck in front of the sail and on the face of the sail of the picture you just posted.. SOKS Sensors. I have this picture but I never noticed it before in those locations . Thanks PeterW I blew it up and highlighted it to reveal better what I am talking about. Its not a very good picture now except to make the point.
Name:	Victor with SOKS sensors.jpg
    • Peter W
      • May 2011
      • 511
      #887
      Mark i do have a better image but it won't let me post it, probably because it is a bitmap.
      Peter.
        PeterW, look under programs and see if you have "Paint". Most computers do. Using Paint you can easily convert it to a JPEG or JPG. Check first, and if you do Ill give you a step by step.
          Collins class HMAS WallerClick image for larger version
Name:	Waller closer.jpg
          • Peter W
            • May 2011
            • 511
            #890
            Mark, Tom I have managed to change the image to a jpeg. Not sure actually if it shows it better or not.
Name:	victor II 1.JPG
              • 3762
              #891
              Looking at how much is below the waterline, if I build one, I will just throw some sand on the hull to represent the growth.
                • 13991
                #892
                Or talc.............................
                • Tugfan
                  • 178
                  #893
                  [ATTACH=CONFIG]16162[/ATTACH]
                  I've never seen a model boat with this much gunk. Maybe someone could do one.
                    • 13991
                    #894
                    A tired old VICTOR that had been sitting at an inactive pier for years without up-keep. Atypical.
                      You could dust it with cornmeal for that effect, but there is textured spray paint in flat colors at Home Depo that will do the trick nicely. Perhaps a combination of both to get the graded effect, as the growth is heavier as you get lower below the waterline. I might have to try it out on a piece of PVC, before I go applying it to a model. It would be a ***** to have to sand it all off if it doesnt work out. The sensored word would be witch with a capital B to be politicly correct
Name:	USS Scranton.jpg
ID:	73771Click image for larger version
Name:	Scranton sail top front.jpg
ID:	73772Click image for larger version
Name:	Scranton sail top rear.jpg
                          Virginia class moving along pretty good.Click image for larger version
                            View over the bow from USS RequinClick image for larger version
                              • 651
                              #899
                              Spooky, I drove past it today
                              • Peter W
                                • May 2011
                                • 511
                                #900
                                another crusty Russian. this time the kilo with the pumpjet.
