Daily submarine picture
This is a sticky topic.
    • 13887
    #526
    Also prevents the span-wise flow of fluid that, when it spills off at the end of the surface, produce a vortex swirl -- which is an ingredient of what a wake-homing torpedo looks for.
      Akula sail closeupClick image for larger version
        DADGUMMIT! Howd that Delta getin thar?
        • reddevil
          • Jun 2009
          • 346
          #529
          I'll try to get a pic of my AKULA II fin finished and compare with the upper one.
            aerial headon of a Delta comin right at ya.Click image for larger version
              Yankee notch sitting pretty.Click image for larger version
                Pretty heavy angle on the dangle.Click image for larger version
                  Swedish U-3 Museum subClick image for larger version
                    check out the angle on the U 3
Name:	U 3blow.jpg
                    its an amazing story how they moved it to the museum
                      Yes, the same with the Albacore, a long and involved process.
                        Upclose on a French Scorpene bowClick image for larger version
                          A sonar image of a sunken U-boat. It looks to me like a type VII. If you look on the deck forward of the conning tower you can see the four escape shafts except that they are on the wrong side , so the picture is reversed somehow.Click image for larger version
                          • reddevil
                            • Jun 2009
                            • 346
                            #538
                            Weren't they vertical mine tubes?
                            • gantu
                              • 420
                              #539
                              Itīs an type VIIC in norway as far i know
                              Regards Gantu
                                reddevil, Ive heard both but I believe that when I was building my Revell model of this thing that the text said they were escape shafts or modules or something like that.
