1/35 scale type 23
    Thanks Dave. Additional progress on my Hydrogen Peroxide wonder. Got all the tabs on and installed the hold-down fitting in the back. I put a light film of thin oil on the threads of the screw so that the CA wouldnt get into it. After previously drilling a hole thru the top hull to establish the proper place I installed the ingeniously shaped piece of renshape that was pre-threaded. Carefull.....try it both ways to see which way fits best. The flat side out worked for me. Put the screw thru the top and wick in CA around the renshape piece.
    Later I mixed up some two part DOT epoxy and poured it in the keel to firm up that area. Dont forget to tape up the bottom so it doesnt leak out while its trying to set, and make sure you level the hull both ways so as it seeks its own level , you wont be disappointed.Click image for larger version
Name:	Fuji transfer 709.jpg
ID:	90661Click image for larger version
Name:	Fuji transfer 710.jpg
ID:	90662Click image for larger version
Name:	Fuji transfer 713.jpg
ID:	90663Click image for larger version
Name:	Fuji transfer 715.jpg
ID:	90664Click image for larger version
Name:	Fuji transfer 721.jpg
      • 3768
      #77
      Still wasnt satisfied. Took the file and went around it above and below the lens to round the cylinder at the junction. Then hit it with 320 paper to take out the scratches. Fortunately when I paint it the paint will fill and blend where I cant and make it look a lot better. SEE WHAT YOU STARTED TOM! Sheesh!
      (Pointing east) It's Manfred's fault! He started it!
        • 1658
        #78
        Boy!!!, it's just like inside the kindergarten, give everybody candy from the forbidden jar, and they tell the nanny you did this, welcome to the dark side kiddoos!!!!!!, once you're in, no escape possible, deal with it!!!!
        • crazygary
          • Sep 2012
          • 610
          #79
          Welcome to the Hotel California....!
          Resistance is futile! Hah!!
          Really like the epoxy ribbon at the bottom of the hull!
          Gotta remember that one! Good call, greenman407!!
          CG
            • 3768
            #80
            Oh why, oh why didn't I take the blue pill......
              • 14005
              #81
              ... welcome to Room-101, have a seat.
              • crazygary
                • Sep 2012
                • 610
                #82
                Grape Kool-Aid, anyone!! (LOL)
                CG
                  OK, Im going to show my ignorance here. What is room 101, grape Kool-aid and Blue pills? Sorry, I dont get out much.
                    Todays limited progress. I installed my hold-down hooks over the battery WTC area. Also, I tried to address the bubble trap under the sail by drilling a hole in the far back of the middle plate in the sail. Also, all the little holes on top of the muffler cover behind the sail I drilled out and a few of them a size or two bigger. I couldnt help myself but I had to put a few more bits on the sail and deck. Pretty happy with the way the top fits on the hull. Ill be making a few more adjustments here and there to it as I go along.
                    Next up, we start working on modifying my "Garage Sale" subdriver into something the type 23 can use.
Name:	Fuji transfer 723.jpg
ID:	90690Click image for larger version
Name:	Fuji transfer 727.jpg
ID:	90691Click image for larger version
Name:	Fuji transfer 729.jpg
ID:	90692Click image for larger version
Name:	Fuji transfer 730.jpg
ID:	90693Click image for larger version
Name:	Fuji transfer 732.jpg
Name:	Fuji transfer 734.jpg
ID:	90695Click image for larger version
Name:	Fuji transfer 737.jpg
ID:	90696The snorkel, at least on mine, is a friction fit. Thats Cool! That way I can leave it down or push it all the way up.Click image for larger version
Name:	Fuji transfer 739.jpg
ID:	90697Click image for larger version
Name:	Fuji transfer 741.jpg
ID:	90698Click image for larger version
Name:	Fuji transfer 743.jpg
ID:	90699Click image for larger version
Name:	Fuji transfer 745.jpg
                        Take a look at this paint scheme. Are we all in agreement that what looks like a white stripe on the hull is actually a yellow stripe? DAVE.....................MANFRED? That would be the best paint scheme so far presented. I could tape that off and airbrush a bright yellow stripe on there and be in HOG HEAVEN!Click image for larger version
Name:	Fuji transfer 746.jpg
                        • crazygary
                          • Sep 2012
                          • 610
                          #87
                          Well, Sir! Ah cain't speak up fer them other guys, but the "grape kool-aid" thing be in
                          reference to the "hale-Bopp" screwball, some yarn back, whut done told his "flock" that,
                          if ya drinks the Kool-Aid, the space ship'll be here a bit sooner to "rescue" us from the
                          dreaded forthcomin' uh the end of th' worl'!!
                          I be guessin' that the "101" mention has sumthin' ta do with sum kinda basic learnin' stuff ( Huh, M?), an' the "blue pill""....
                          Well!! Kin you say "Vie-aggra"???? Am that it, Tom?? Er do I be 'spectin' sumfin else?? (LOL)
                          This be too much dern fun, y'all!!
                          CG
                          • crazygary
                            • Sep 2012
                            • 610
                            #88
                            CG
                              • 3768
                              #89
                              Well!! Kin you say "Vie-aggra"???? Am that it, Tom?? Er do I be 'spectin' sumfin else?? (LOL)CG
                              Movie - Matrix.
                              • crazygary
                                • Sep 2012
                                • 610
                                #90
                                Oops!! Sorry 'bout the double post!!
                                Ah dun "pulled a Dave"!!
                                CG
