1/35 scale type 23
    Thanks Manfred, I need people to keep an eye on me to keep me from making a CATASTROPHIC booboo. Well here it is all opened up. I dont think that there is enough room to drill another hole in that arm so I think that I will thin out the inside of the inspection hatch somewhat and take a little off of the end of the arm. You know.......compromise. The hatch and the surfaces need to be cleaned up a little more. Ill probably leave the hatch off, just in case until its time to paint it after everything else is sorted out. The fittings kit came with one velcro holddown strap, I need two. So Ill put some hooks into the supports in the front for the battery WTC.Click image for larger version
Name:	Fuji transfer 570.jpg
ID:	90390Click image for larger version
Name:	Fuji transfer 573.jpg
ID:	90391Click image for larger version
Name:	Fuji transfer 574.jpg
ID:	90392Click image for larger version
Name:	Fuji transfer 576.jpg
ID:	90393Click image for larger version
Name:	Fuji transfer 583.jpg
ID:	90394Click image for larger version
Name:	Fuji transfer 584.jpg
ID:	90395Click image for larger version
Name:	Fuji transfer 585.jpg
      While I was at it I stuck the Subdriver and battery WTC inside to get a feel for things.Click image for larger version
Name:	Fuji transfer 578.jpg
ID:	90397Click image for larger version
Name:	Fuji transfer 580.jpg
ID:	90398Click image for larger version
Name:	Fuji transfer 582.jpg
        • 3438
        #48
        Greenman,
        Can you show the diamond blade you used to cut the hull.
          Sure I can Mr. Redboat. Here they are. I used the larger one on this job. The smaller one comes mounted on a shaft. The larger one has to be mounted on this spring loaded Mandrel deal thing.Click image for larger version
Name:	Fuji transfer 592.jpg
ID:	90406Click image for larger version
Name:	Fuji transfer 593.jpg
ID:	90407Click image for larger version
Name:	Fuji transfer 594.jpg
            Redboat, how were you affected by the Typhoon that hit the Philippines? I hope that you and your family were spared.
              Heres a couple shots that I didnt get around to posting. Waste not what not.
Name:	Fuji transfer.jpg
ID:	90409Click image for larger version
Name:	Fuji transfer 587.jpg
ID:	90410Click image for larger version
Name:	Fuji transfer 588.jpg
                • 3438
                #52
                Thanks Gman. Was looking for a local source of the Dremel mini ripsaw but couldn't find one. All that's available looks similar to wjat you used. I see that it can very much handle the job, might get one myself.
                We live in the suburbs just outside the capital Manila. We only experienced very high gusts of wind and few heavy rains. We were lucky compared to those hit by the storm surges. I believe some of Ellie's relatives were affected.
                  • 13598
                  #53
                  Yes, some nieces were flooded out, but no deaths we've heard of.
                    I just couldnt stand it! I had to put that beautiful sail together. I took one picture of it in my hand so that you could see how large it is, not to mention the fantastic detail. Obviously there are more parts. Ill put the grab irons on later. The hatch tube going down into the sub....I didnt need it so I nixed it. Ive got the hatch closed.. Also, that periscope. I think I want a crack at doing something with it. Stay tuned.Click image for larger version
Name:	Fuji transfer 608.jpg
ID:	90485Click image for larger version
Name:	Fuji transfer 610.jpg
ID:	90486Click image for larger version
Name:	Fuji transfer 611.jpg
ID:	90487Click image for larger version
Name:	Fuji transfer 612.jpg
ID:	90488Click image for larger version
Name:	Fuji transfer 613.jpg
ID:	90489Click image for larger version
Name:	Fuji transfer 614.jpg
ID:	90490Click image for larger version
Name:	Fuji transfer 615.jpg
ID:	90491Click image for larger version
Name:	Fuji transfer 616.jpg
                    • crazygary
                      • Sep 2012
                      • 610
                      #55
                      Nice, But where the heck to the keys go in???
                      CG
                        DUH! Or as Homer Simpson would say ....Doughhhhhhhhhhhhhhhh! Those are my keys to the Nissan and the Ford and dont forget my Pink Panther key to the house. As you probably guessed, they are there to provide a size comparison. As if you didnt know, you trouble maker.
                        • crazygary
                          • Sep 2012
                          • 610
                          #57
                          Information regarding your Pink Panther Key should be given out on a strict
                          "need-to-know" basis, only!! (LOL)
                          CG
                          • Sublime
                            • Jan 2014
                            • 48
                            #58
                            Wow, do you use that air rifle to install all the limber holes and vents? I never thought about doing that.
                              • 13598
                              #59
                              You Bum's keep the thread on-topic ... or, I release the Cat!
                                You cant do that..........................were allergic!
