Bronco Type XXIII by Ken
  • Ken_NJ
    • Sep 2014
    • 977
    #166
    Assembling the sail
    Since I'll be doing something mechanical in the sail I wanted to make it easily serviceable. So I'm making it splittable without seeing any fasteners. Like the hull not sure how this will work out.
    What parts do I need, and not need. Determining that here.
    Click image for larger version  Name:	A_IMG_0176.jpg Views:	0 Size:	57.5 KB ID:	190159
    These holes needed to be opened up so did that. The tabs were solid, so drilled holes through the tabs and cleaned up with a fine file.
    Click image for larger version  Name:	B_IMG_0178.jpg Views:	0 Size:	51.6 KB ID:	190160
    Click image for larger version  Name:	C_IMG_0177.jpg Views:	0 Size:	49.1 KB ID:	190161
    The top of the sail was attached to the starboard side of the sail with solvent. The port side will be removeable.
    Click image for larger version  Name:	D_IMG_0180.jpg Views:	0 Size:	54.9 KB ID:	190158
    Click image for larger version  Name:	E_IMG_0179.jpg Views:	0 Size:	53.8 KB ID:	190156
    Shaped and added these tabs.
    Click image for larger version  Name:	F_IMG_0305.jpg Views:	0 Size:	47.4 KB ID:	190154
    They get a machine screw to hold this part together.
    Click image for larger version  Name:	G_IMG_0306.jpg Views:	0 Size:	48.7 KB ID:	190155
    The top aft port side gets these tabs.
    Click image for larger version  Name:	H_IMG_0311.jpg Views:	0 Size:	42.0 KB ID:	190157
    Click image for larger version  Name:	I_IMG_0312.jpg Views:	0 Size:	42.3 KB ID:	190162
    Which slide in when attached both halves together.
    Click image for larger version  Name:	J_IMG_0313.jpg Views:	0 Size:	41.0 KB ID:	190164
    And gives a nice not so noticeable joint. Thank you Bronco for making accurate parts.
    Click image for larger version  Name:	K_IMG_0314.jpg Views:	0 Size:	39.8 KB ID:	190163
    The exhaust housing gets these two acrylic parts. They were shaped as one unit to fit in position then cut in half so one piece is attached to each half of the sail. Holes were then drilled on the drill press and they were tapped for 2-56.
    Click image for larger version  Name:	L_IMG_0315.jpg Views:	0 Size:	44.5 KB ID:	190165
    Click image for larger version  Name:	M_IMG_0316.jpg Views:	0 Size:	44.5 KB ID:	190168
    The connecting piece was then made. The screw on the right is a through hole. The one on the left is a slot. When the sail is taken apart I just need to loosen the slotted screw. The 8-32 bolt will go through the deck holding the sail down to the hull
    Click image for larger version  Name:	N_IMG_0323.jpg Views:	0 Size:	46.7 KB ID:	190171
    Notice the ribs were filed down at TDC to allow any air bubbles to pass wherever they want to go.
    Click image for larger version  Name:	O_IMG_0324.jpg Views:	0 Size:	46.3 KB ID:	190167
    Added these two acrylic foundations at the forward end.
    Click image for larger version  Name:	P_IMG_0317.jpg Views:	0 Size:	46.0 KB ID:	190166
    And made a similar mounting point at the forward end of the sail.
    Click image for larger version  Name:	Q_IMG_0325.jpg Views:	0 Size:	44.3 KB ID:	190169
    Click image for larger version  Name:	R_IMG_0321.jpg Views:	0 Size:	44.8 KB ID:	190170
    Click image for larger version  Name:	S_IMG_0326.jpg Views:	0 Size:	46.4 KB ID:	190172
    These are the two parts that hold the sail to the deck. The knurled nuts hold the sail to the deck with the 8-32 bolts.
    Click image for larger version  Name:	T_IMG_0318.jpg Views:	0 Size:	39.8 KB ID:	190173
    Click image for larger version  Name:	U_IMG_0319.jpg Views:	0 Size:	39.6 KB ID:	190175
    Like this. I first used this method on my Marlin about 13 years ago. It works very well.
    Click image for larger version  Name:	V_IMG_0328.jpg Views:	0 Size:	54.0 KB ID:	190176
    Sail attached to the deck.
    Click image for larger version  Name:	W_IMG_0335.jpg Views:	0 Size:	57.0 KB ID:	190174
    Forward joint. Not sure yet what to do on the ladder rungs. That is a future decision.
    Click image for larger version  Name:	X_IMG_0310.jpg Views:	0 Size:	43.5 KB ID:	190177
    The exhaust housing area. There will be a seam. Again, thanks to Bronco for decent work.
    Click image for larger version  Name:	Y_IMG_0327.jpg Views:	0 Size:	41.5 KB ID:	190179
    I had to file down the deck area forward on the section that positions the sail so the sail would fit. See the scratches. Those will be cleaned up at a later time.
    Notice the lower scuppers against the hull, you can see the deck thingy that positions the sail. That will require attention, later.
    Click image for larger version  Name:	Z1_IMG_0331.jpg Views:	0 Size:	47.9 KB ID:	190181
    Same applies here
    Click image for larger version  Name:	Z2_IMG_0332.jpg Views:	0 Size:	49.2 KB ID:	190178
    Click image for larger version  Name:	Z3_IMG_0333.jpg Views:	0 Size:	49.0 KB ID:	190180
    Click image for larger version  Name:	Z4_IMG_0334.jpg Views:	0 Size:	48.7 KB ID:	190182
    Not sure if I'll ave another post before Groton, have much to do.
      • 1533
      #167
      That sure is a slick build. Very nice.
