GATO! (It has begun)
    Uuhmeraa.....You could also check and see If they still have any Sombra 6 ch. left.
      • 3751
      #197
      Email Mike directly. I can not find everything they sell on the website.
      • matthewnimmo
        • Dec 2011
        • 271
        #198
        Originally posted by matthewnimmo
        [ATTACH=CONFIG]26555[/ATTACH]
        Guys, are we sure this is correct? Reason why i'm asking is that when i take my volt meter to just my battery (black end to the black end of the battery and red to red) i get 11.1 volts like normal.....but after i plug the battery in and test on the female end right before i connect to all of my components (like the ESC, LIPO, etc) i have to match my volt meter's black to the RED and and volt meter's red to the BLACK end of the dean connector......i'm scared to plug this in lol....did i f*ck somthing up in my initial drawing?
        Thanks,
          • 13973
          #199
          Thanks,
          Do it like this:
ID:	90500Click image for larger version
          (still looking for better photos, Matt).
          • crazygary
            • Sep 2012
            • 610
            #200
            Look closely at the Deans connectors and you can see that they can't be wired in an identical fashion!
            A single prong on one and and two prongs on the other. If you wire them the same, once you connect them together,
            you'll end up with mismatched polarities.
            Whichever way you wire the connector to your battery, note which wire lines up with the single prong on
            the other side. Wire the other connector opposite of the way you wired the first one. When they're connected together,
            black will be to black, and red will be to red.
            A simple mistake to make, but also a simple fix!
            CG
              • 3751
              #201
              Yes there is something wrong! From battery to BEC and ESC. The BEC output to all the other devices.
              Edit Note: I am getting myself confused..........not trying to add to the craziness, sorry.
              • matthewnimmo
                • Dec 2011
                • 271
                #202
                Ok guys, here are some pictures to describe everything just to be super clear before testing any further.
                1) Click image for larger version
ID:	90502 The red arrow as you can see is taking the batteries red line down through the main line through the WTC (the main line section used is the side with the black stripe)
                2) Click image for larger version
ID:	90503 This is the same line on the other side of the WTC (notice the black stripe on the wire ... so its still the red lead from the battery).
                3) Click image for larger version
ID:	90504 Can you guys see my problem now? I'm pretture sure thaClick image for larger version
ID:	90505t i need to flip the wiring from picture number one; but I've been seeing positives and negatives too long today that i just need a fresh pair of eyes. See the arrows are pointing to the Black leads to the rest of my devices (ESC, LIPO, etc).
                4) Click image for larger version
ID:	90506 Volt reading directly from the battery. Red needle to red lead on battery and black needle to black lead on battery. 11.1v
                5) Click image for larger version
ID:	90507 Volt reading from the end of the wire that goes through the WTC after the switch is turned on. I have to put the red needle to what would be the BLACK connection to the rest of my sub components, and the black needle to the red connection:(
                Plausible conclusion
ID:	90508 If i'm correct that i've F'd up the polarity ... is it as simple as switch those two wires around? I'm thinking yes?
                Thanks everyone!
                  • 13973
                  #203
                  You got the male Dean's plug at the after dry space end ass-backwards. Swap the wires to the poles on the plug and you're good.
                  • matthewnimmo
                    • Dec 2011
                    • 271
                    #204
                    Oh please tell me theres a different option? That was the biggest pain in the ass to solder with so many wires going to those poles
                      • 3751
                      #205
                      As you work on it, just remember the "t" of the deans plug is positive.
                        • 13973
                        #206
                        Suck it up, GATO-boy. Fire up the soldering iron and get to work!
                          • 13973
                          #207
                          • matthewnimmo
                            • Dec 2011
                            • 271
                            #208
                            Yes sir!!! Stupid pain in the ass wires. Getting close though for sure
                              • 13973
                              #209
                              Hey, you're doing this right. You checked with us, you checked with the mulit-meter, and when you did not get the polarity you thought you should have, you asked for help. You did not go in stupidly throwing the big hairy, Frankenstein knife-switch -- which would have fried everything and set the atmosphere on fire (with apologies to Teller) killing us all. You wanted to be sure. You played it safe ... though I know it was killing you to throw the switch. You made the smart move.
                              Good man!
                              I'll sign your Card.
                              • matthewnimmo
                                • Dec 2011
                                • 271
                                #210
                                Good news, I've got my male red dean connector switch on the aft side ...
                                But
                                I decided to take a look at my radio and receiver like you mentioned David and it is 72mhz on the back of the transmitter and so are the crystals:( Who do i contact from sub-driver.com to send me the right component and crystals?
                                See pic below
                                I can give you guys pics of the crystals too if needed; but as of right now i have a 72mhz trx/rx not a 75mhz.
