    • Jan 2020
    • 1036
    #166
    Your very kind. Yes. Yes. I am wonderful, ain't I?
    Tired of me yet?
      • 13977
      #167
      Tired of me yet?
      **** no!
      You punch back. I like that!
        • 13977
        #168
        What's happening here? Is this before the black wash?
        Nope.
        Two steps removed from when the wash was sprayed on. After scrubbing the wash into every nook and corner.
        I then achieve a very subtle streaking effect with a soft brush following the gravity line. That's what's being represented in this picture.
        Oil paint dries very slowly, so no rush. The drying is accelerated with a heat gun (careful, things can go terribly wrong here) and a few days of sitting by its lonesome. At that point I get into the rusting agent application.
          • 13977
          #169
          What are these mediums and how are they used?
          Click image for larger version  Name:	Image 4.jpg Views:	0 Size:	49.8 KB ID:	176104
          Get this stuff. 1 pt Modern Masters ME208 Iron Metal Effects Reactive Metallic Paint - Walmart.com​
          Plenty of how-to tutorials on YouTube.
            • 13977
            #170
            Are you using anything on the cotton or paper towel to remove excess? Are you removing all wash except the weld lines?
            The cotton and soft paper towel are used neat. They wipe away most of the wash from flat areas. Leaving wash around weld beads and into crevasses and negative draft areas. Washes and dry brushing are forms of false high lighting. These techniques used sparingly and to the correct surfaces makes the finished display 'pop' to the observer.
              • 13977
              #171
              Is this Majestic Touch wash black? If so, I cannot find it, do you know where you got it from or an alternative?
              Any linseed oil-based paint brand will do -- just go to an 'artist' store and ask the lisping, blue-haired, cattle nose-ringed, goth freak at the counter where the oil paints are. (Try not to laugh in her/his/it's... whatever's face when you do this). Don't forget the turpentine thinner/solvent.
                • Jan 2020
                • 1036
                #172
                LOL, yes, it will be a True Holiday experience! Yes, I have the turpentine thinner/solvent dialed in to my shopping list!
                  • Jan 2020
                  • 1036
                  #173
                  Something David taught me long ago when I built my OTW Type XXIII. The waterline scum line looks better when you use a fan blender brush with the scum color loaded onto it, and you draw downwards from the scum line and you do it in different lengths as you work your way across the hull.
                  One other thing he taught me for this specific boat…most XXIIIs were operating in cold water areas. The scum line was probably more beige/brown with little green.
                  Just adding something to consider as you finish your weathering.
                  Hope that was OK to add onto what David is teaching…
                  what medium(s) did you use to attain the beige/brown scum effect? Do you also have a photo? Thanks
                    • Jan 2020
                    • 1036
                    #174
                    Click image for larger version  Name:	DSCN0094.jpg Views:	0 Size:	86.4 KB ID:	176116
                    David, I am guessing you know what my next request is....... would you share the mediums and techniques you used to do the XXIII Scum line and below? I was going to wait to ask, but want to have a plan and shopping list!
                    Click image for larger version  Name:	Image 74.jpg Views:	0 Size:	47.4 KB ID:	176127 Click image for larger version  Name:	Image 87.jpg Views:	0 Size:	48.0 KB ID:	176129
                      • 13977
                      #175
                      Do I have a photo?
                      Do.
                      I.
                      Have.
                      A.
                      Photo????
                      You're kidding!?... right?
                      The adhesive is water soluble (but becomes waterproof once dry) 'artist medium', used to prepare canvas for paint work. Another visit to woke-land (art supply store) will net you this stuff. The green 'Turf' is sold wherever they sell model train stuff.
                        • Jan 2020
                        • 1036
                        #176
                        Do I have a photo?
                        Do.
                        I.
                        Have.
                        A.
                        Photo????
                        hahahahah, I know you got pics! What did you spray the lower hull below the scum line for the XXIII weathered look? Click image for larger version
                          • 13977
                          #177
                          hahahahah, I know you got pics! What did you spray the lower hull below the scum line for the XXIII weathered look? Click image for larger version  Name:	Image 87.jpg Views:	0 Size:	48.0 KB ID:	176133
                          2K polyurethane dark gray below waterline followed by rag and texture-sponge stippling with lighter shades of gray. Some tooth-paste masking between sponge applications to mix things up a bit.
                            Another taking over a post. Dave, stop.
                              • Jan 2020
                              • 1036
                              #179
                              David, what paint and color green is the waterline?
                                I wanted more pictures and using reverse psychology, I got them. Great tutorial.
