Bronco 1:35 Type XXIII RC Build/ Conversion
  • biggsgolf
    • Jan 2020
    • 1036
    #241
    I purchased the Dual shaft, hoping to leave the Gearbox in place, and if I build a dual prop sub can use this SubDriver in it as well
    • biggsgolf
      • Jan 2020
      • 1036
      #242
ID:	178387 Dive Planes in progress, the wights are not secured yet.
      Click image for larger version  Name:	IMG_2523.jpg Views:	0 Size:	94.9 KB ID:	178384 Click image for larger version  Name:	IMG_2525.jpg Views:	0 Size:	86.3 KB ID:	178385 Click image for larger version  Name:	IMG_2526.jpg Views:	0 Size:	97.3 KB ID:	178386
        Bruce,
        That's a great idea! Then I guess all you need to do is fabricate another gear box for the new boat. I do the same thing with most of my single prop boats.
        Your build is looking good!
        "Firemen can stand the heat."
        • biggsgolf
          • Jan 2020
          • 1036
          #244
          Navigation lights now operational
          • biggsgolf
            • Jan 2020
            • 1036
            #245
            Stern mechanics complete, Bow planes completed, front SubDriver stop/saddle installed
ID:	178466 Click image for larger version
            • biggsgolf
              • Jan 2020
              • 1036
              #246
              Removable magnetic support for hull
              • biggsgolf
                • Jan 2020
                • 1036
                #247
                Cylinder is pressure proof and operational as are the linkages. My cat grabbed the upper hull and the navigation lights wires and separated the sail...... also, I drilled a hole in the bow end cap and miscalculated its position so the end cap warped when tightened down so reaching out to Bob about getting a new end cap. I repurposed old end cap which works perfect, will need to add a servo for bow dive planes. Next I will now start the trimming process.
                • biggsgolf
                  • Jan 2020
                  • 1036
                  #248
                  Added a magnetic switch between the battery and Remote Control so Remote Control will not drain the battery
                  • biggsgolf
                    • Jan 2020
                    • 1036
                    #249
                    Initial submerged trim good results, she is stable and level, next step will be adding floatation foam. 7" ballast tank seems perfect, thanks Jason & Bob.
                    • biggsgolf
                      • Jan 2020
                      • 1036
                      #250
                      Surface Trim is good, will adjust foam vertically to dial submerged trim.
ID:	179154 Click image for larger version
ID:	179155 Click image for larger version
ID:	179156 Click image for larger version
                      • biggsgolf
                        • Jan 2020
                        • 1036
                        #251
                        3D Printed Stand, she is going in the water this week.......
                          Looking awesome. Love the paint work on this one.
                          • biggsgolf
                            • Jan 2020
                            • 1036
                            #253
                            Thanks! I have gotten hooked on weathering
                            • biggsgolf
                              • Jan 2020
                              • 1036
                              #254
                              OK! She did well surfaced, turn was successful! That was my biggest concern if she would turn in my 14' wide pool. The larger rudder worked, no extension needed. The submerged trim needs more foam above the waterline. Video link below:
                              • biggsgolf
                                • Jan 2020
                                • 1036
                                #255
                                Surface run good, still sorting cylinder issues for submerged trim.
