    • Jan 2020
    • 1009
    #91
    You've successfully hurtled the hardest part of this project. Well done, sir.
    David where should the cylinder be placed? Mine is 2.5”, 23” long including a 7” ballast tank.
      • 13608
      #92
      Longitudinally, place the center of the ballast tank at the center (half-way point) of the hull.
        • Jan 2020
        • 1009
        #93
        Thank you Sir!, and appreciate the aditional operations
          • 13608
          #94
          Yeah. And note the need to make the attachment of the bow and stern plane 'guards' much more robust than what the kit calls for. Those will snap off if you don't reenforce the bond between guards and hull.
            • Jan 2020
            • 1009
            #95
            Thanks, will do!
              • 1568
              #96
              Was wondering about that. Good call.
                • Jan 2020
                • 1009
                #97
                Originally posted by Das Boot
                Dave,
                did you add any grates on the bottom of your XXIII? I didn’t notice in Georgia.
                David why did you cut an opening below the sail? Click image for larger version
                  • 3667
                  #98
                  I can speak for me, to get air out quickly.
                    • 1568
                    #99
                    Could be for the camera system he put in it.
                      • Jan 2020
                      • 1009
                      #100
                      Creating Periscope which will house my antenna and be attached to hollow Aluminum TubeClick image for larger version  Name:	Image 10-26-23 at 5.09 PM.jpg Views:	0 Size:	49.8 KB ID:	175332
                        • Jan 2020
                        • 1009
                        #101
                        Final print will be grey Click image for larger version
                          • 13608
                          #102
                          To vent the free-flooding hull and reduce displacement of the above waterline structures.
                            • Jan 2020
                            • 1009
                            #103
                            Fittings etc. from Danny arrived today! Not sure how many I will use yet Click image for larger version
                              • 1568
                              #104
                              Missed it by that much.
                                • Jan 2020
                                • 1009
                                #105
                                Once cleaned up will be quite good
