    Off topic, but when ham radio Click image for larger version
ID:	175074 camping is done, on to the XXIII for a winter project.
      • Jan 2020
      • 1036
      #77
      Using a brass rod leveled to determine Cylinder Cradle and Thrust Bearing height Click image for larger version
        • Jan 2020
        • 1036
        #78
        Perfect alignment
          • Jan 2020
          • 1036
          #79
          I am very happy with the cut lines, no Styrene needed, used Rage in two spots, the magnetic hold down is perfect Click image for larger version
            • 13979
            #80
            Looking good, pal.
              • Jan 2020
              • 1036
              #81
              Looking good, pal.
              Thanks David!
                • Jan 2020
                • 1036
                #82
                Thrust Bearing, final will be thicker Click image for larger version
ID:	175096 Click image for larger version
                  Looks great. My diamond cutting wheels have been delivered.
                    • Jan 2020
                    • 1036
                    #84
                    Unrelated, Last Pool Run Skipjack 2023
                      • Jan 2020
                      • 1036
                      #85
                      Ok, seams and hull clips complete Click image for larger version
                        Looking great.
                          • 13979
                          #87
                          You've successfully hurtled the hardest part of this project. Well done, sir.
                            • Jan 2020
                            • 1036
                            #88
                            Thanks David
                              • Jan 2020
                              • 1036
                              #89
                              This is a better pic, last pic was distorted Click image for larger version
                                • Jan 2020
                                • 1036
                                #90
                                Port Side Seam
