    Lowest speed setting?
      • Jan 2020
      • 1036
      #47
      Highest RPM
        • 13979
        #48
        Highest RPM
        YEAH, BUDDY! kick-ass MF'er!
        (starting to like this newb)
        The Horrible
          • Jan 2020
          • 1036
          #49
          Will be 3D fabricating Hull Taps as I clean up the cuts
            • Jan 2020
            • 1036
            #50
            (10 per side every 63MM), the Hull screw down I will cut from a Torpedo Tube
              • 13979
              #51
              Next I will clean up the cut lines. David, any advice on cleaning up the Kerf would be appreciated!
              Just run a knife-edge along the side of the cut, which will cut/snap off hanging shards of kerf.
              Replace plastic lost to kerf with. 040" (or thereabouts) strips of styrene.
                • Jan 2020
                • 1036
                #52
                Will do David, thanks
                  • Jan 2020
                  • 1036
                  #53
                  Fabricating tabs Click image for larger version
Name:	Image 10-14-23 at 3.46 PM.jpg
                    • Jan 2020
                    • 1036
                    #54
                    First test hull tab Click image for larger version
                      • Jan 2020
                      • 1036
                      #55
                      Tab is rotated 90 Degrees for printing
                        • Jan 2020
                        • 1036
                        #56
ID:	174935Here you can see the curved tab better
                          Will you be using the kit's prop?
                            Bob has brass props.
                              • Jan 2020
                              • 1036
                              #59
                              I am going to use Prop from Danny, did not know Bob still sells them
                                • Jan 2020
                                • 1036
                                #60
                                Fabricating magnetic hull closure parts Click image for larger version
