    • Jan 2020
    • 1009
    Removed nubs on keel, scored, sawed with dremel, and snipped un needed internal supports
      • Jan 2020
      • 1009
        • Jan 2020
        • 1009
          • Jan 2020
          • 1009
          Scoring the supports really simplifies the snipping process. The Diamond Cutting wheel did awesome and gives me confidence for when I do the Horizontal Hull cut.
            • 3452
            Which parts are you looking for?
            Thrust bearing support and internal bulkhead/wtc support.
              • Jan 2020
              • 1009
              When I get to those, remind me and I can send you what I fabricate.
                • 3452
                Will a mini circular saw give a cleaner cut than a diamond wheel? Click image for larger version
                  • Jan 2020
                  • 1009
                  I am doing what David does by using Diamond wheels, seems to me that a thinnest blade will be best and large teeth will jerk the model and rotary around causing major issues, just my opinion, mine are .60 MM
                    • 1568
                    What I’m going to remember from Dave’s posts, is TAKE YOUR TIME. Score the plastic slowly, as many times as it takes. I have to keep this in my head when it’s my time to start. I think this is probably the hardest part of the build, but can be accomplished with patience.
                      • Jan 2020
                      • 1009
                      Yes, it's not one continuous cut, small slow jabs working in depth. Should take an hour.
                        • Jan 2020
                        • 1009
                        Ok, installed grills in hull, Torpedo Doors, marked where rudder rod holes will be, drilled 1MM hole for rudder control wire if I choose over a wheel lock, and glued the halves together.
                          • Jan 2020
                          • 1009
                          Next I epoxied the hull halves keels on the inside before gluing together. Tomorrow I will epoxy the upper hull seams.
                            • 1568
                            Are you going to cut any extra flood grates in the bottom of the hull?
                              • Jan 2020
                              • 1009
                              Yes I do Click image for larger version
Name:	Image 10-13-23 at 8.00 AM.jpg
                                • Jan 2020
                                • 1009
                                #30
                                Rough fabricating the WTC Cradles Click image for larger version
