Project 665 Whiskey long bin 1/50
    • Oct 2017
    • 1005
    Hi! This is a short presentation of the assembly and outfitting of the 1/50 Kit once produced by Mr. Lazar Kerzmann. I purchased it in 2018. It tourned out beeing the prototype that had been partially assembled by himself and soon was given to a fellow modeller who later returned it to Mr.Kerzmann. Originally build as a dry hull like the large old Engel kits, i am converting it into a wet hull with 2 dry compartments, a large snort balast tank, main drive and separate service battery, retractable bow planes, retractable masts.The pictures show the config with a small piston trim tank that will most likely not be installed finally. No newer pictures yet. The plane mechanism provided with the model was useless and had to be rebuild.
    Status as delivered :
ID:	172921Click image for larger version
ID:	172922Click image for larger version
ID:	172923Click image for larger version
ID:	172925Click image for larger version
ID:	172926Click image for larger version
ID:	172928Click image for larger version
ID:	172927Click image for larger version
    Construction of the main compartment: Click image for larger version
ID:	172900Click image for larger version
ID:	172899Click image for larger version
ID:	172905Click image for larger version
ID:	172906Click image for larger version
ID:	172907Click image for larger version
ID:	172898Click image for larger version
ID:	172902Click image for larger version
    forward compartment for bowplane and mast operation:
ID:	172916Click image for larger version
ID:	172917Click image for larger version
ID:	172918Click image for larger version
ID:	172919Click image for larger version
ID:	172895Click image for larger version
    Overview of the principal layout, no wtc cylinders in place:
    working on the upper hull: Click image for larger version
ID:	172904Click image for larger version
ID:	172908Click image for larger version
ID:	172910Click image for larger version
    Reconstruction of the foldable forward planes: Click image for larger version
ID:	172901Click image for larger version
ID:	172903Click image for larger version
ID:	172909Click image for larger version
ID:	172911Click image for larger version
    Not yet on show are the changes to the main compartment.i will delete the trim tank and its roller pump for saving space, mostly for safety concerns. That boat will have a slighly positive bouyancy, gollowing Bob's suggestions about large boats in his book. Will also shorten the compartment. The pre-installed stern tubes were cut free from the surrounding epoxy with a specially self-made cirkular saw and shortened a lot more, too. This helps moving the balast tank further to the boats centre. The gear for the rudder has been replaced with a normal rudder lever.
    Jörg
    • 1994
    Unique boat. I love it!
    I have the molds for this boat now and they're going to end up with Loyalhanna in the coming weeks. Should still be available through me once we get the site updated in a few weeks.
      • 13729
      I am so tempted!
        • 1598
        The hull is familiar, but I’ve never seen a sail like that. Cool boat.
          • 13729
          WHISKEY hull with a 'long bin' sail housing cruise missiles. A carrier killer. Supplanted by the ECHO's.
            • 3547
Name:	images (1) (5).jpg
ID:	173064 https://youtu.be/aYM0SAcDZ0c
              • Oct 2017
              • 1005
              Followed by the JULIETTS. 665 was a whiskey with a new mid-section containing the enlarged sail for four launchers for P5 missiles. Boat was too slow submerged / 12kts and according to several sources, VERY loud.
                • Oct 2017
                • 1005
                Lazar Kerzmann had a build report on a russian forum, showing how he made the master, the hull halves, and assembly of the model. He intended to install four launch tubes from stainless steel, but later sealed, filled, saded and primed all the openings he cutoff the sail prior to selling the boat to me. Click image for larger version
ID:	173067Click image for larger version
ID:	173068Click image for larger version
ID:	173069Click image for larger version
ID:	173070Click image for larger version
ID:	173071Click image for larger version
ID:	173072Click image for larger version
ID:	173073Click image for larger version
                  • Oct 2017
                  • 1005
                  Dug these pics out from my previous mobile. From 2018, i remade the sail lantern, forward underice sonar and exhaust.
ID:	173077Click image for larger version
ID:	173078Click image for larger version
ID:	173079Click image for larger version
                  • DrSchmidt
                    • Apr 2014
                    • 1343
                    I admire the ability of Ruissians to design every bit of elegance out of a submarine...
                      • 3547
                      Did he intend to make the launchers functional (pyrotechnically) ?
                        • Oct 2017
                        • 1005
                        Yup. Every bit of function of the launchers was to be at display. You'd look for the 651 juliett he made, search on youtube
                          • 3547
                          Found it. Wow! He even has a Golf https://youtu.be/3CgdrDgvoeY
                            • Oct 2017
                            • 1005
                            Distinctive walkway... Click image for larger version
ID:	183606 Click image for larger version
                              • 1598
                              I have never seen that kind of boat before. Very unusual looking and a very good job.
