Project 665 Whiskey long bin 1/50
    • 1121
    Hi! Found some time to continue during holidays! I still have got parts for a large wtc kit waiting for assembly and recently purchased a large 1/72 AKULA hull for it, again from Lazar Kerzmann. That one came with a nice though not scale Emergency Buoy that needed instant copy-casting for the Long Bin. Also made some hatches from PU that still need detailing and FINALLY reinstalled the aft stabalizer after tuning to proper appearence. Will install the lanterns next and finish the basic deck details from a new set of blueprints. Had to re-measure and -mark most of the already drawn-down stuff, e.g. position of the aft em-buoy was off.
    Of course, i broke the upper hull right above the forward diveplanes once again and am right now fixing that, will mill out a recess to cast-in one or two grp-rods once the provisional epoxy backup has cured.
    Jörg
ID:	189818 Click image for larger version
ID:	189803 Click image for larger version
ID:	189810 Click image for larger version
ID:	189808 Click image for larger version
ID:	189814 Click image for larger version
ID:	189819 Click image for larger version
ID:	189820 Click image for larger version
ID:	189822 Click image for larger version
ID:	189798 Click image for larger version
ID:	189806 Click image for larger version
ID:	189801 Click image for larger version
ID:	189799 Click image for larger version
ID:	189802 Click image for larger version
ID:	189811 Click image for larger version
ID:	189812 Click image for larger version
ID:	189813 Click image for larger version
ID:	189815 Click image for larger version
ID:	189823 Click image for larger version
ID:	189816 Click image for larger version
ID:	189807 Click image for larger version
ID:	189809 Click image for larger version
ID:	189821 Click image for larger version
ID:	189800 Click image for larger version
ID:	189817 Click image for larger version
ID:	189805 Click image for larger version
      • 1121
      Today i glued the 8mm grp-rod in beetween a cutoff on the upper hull to enhance the stability of that thinnes portion of the deck:
ID:	190119 Click image for larger version
ID:	190120 Click image for larger version
ID:	190117 Click image for larger version
ID:	190116 Click image for larger version
        • 1121
        Black box found ;-)
        Any other tipps for accelerating Epoxy? Am hesitent to use a heat lamp for fire safety...
          • 1121
          The forward deck has been ground flat again, also corrected some slight elevation of the starbord bow. Some epoxy filler will follow, afterwards will takr care of those floodholes...
ID:	190295 Click image for larger version
ID:	190296 Click image for larger version
ID:	190297 Click image for larger version
ID:	190298 Click image for larger version
            • 1121
            Btw, i still fail to find the reason for my pictures showing up that unsharp. Am taking 12M pictures with my phone and scaling them down to 50 percent size. They are sharp on my phone, yet blurry in this forum. Odd... suggestions?
              • 1121
              Does anyone have a good picture or plan depicting the conning topside? That is all i found, tried a KI to improve the quality:
              • gantu
                • 428
                Eventuell hiolft Dir das weiter.
                Regards Gantu
                • CC Clarke
                  • Aug 2020
                  • 320
                  During the 70's the Soviets had hundreds of post-WW II era diesel boats still active. In sonar school, we spent days listening to tapes of each class to help classify them aurally. The Whiskey's had several missile-armed variations, but the propulsion systems were identical.
                  Once we became proficient at identifying the class by sound, we dove deep into the nitty-gritty next phase of classification: LOFAR (Low Frequency Analysis and Recording) grams, which used the same techniques as the SOSUS and Airborne (P-3 and S-3) LOFAR equipment, where a roll of paper slowly printed the noise spectrum and once enough data had rolled out, we grabbed our ten-point dividers and went to work, identifying their unique frequencies and interpolating the results, (propeller turn-counts, diesel engine signatures, and a host of other classification cues) while snorkeling and submerged on their batteries. Their three-shaft diesel boats used belt-driven electric motors on the outboard shafts in silent, "creep" mode, which was anything but quiet.
                  All of the acoustic and frequency info had to be committed to memory (for dozens of diesel and nuclear submarine classes) along with the equations to extract the info. Memory-wise, it was a very challenging course, and one of the requirements to advance from sonar operator to sonar supervisor.
                  The Whiskeys were so loud, it was easy to identify them, and of course, so ugly they were instantly recognizable visually. Like the majority of their missiles, (both cruise and ballistic) all were powered by liquid fuel and filled prior to launch, which is uber-dangerous in an enclosed atmospheric environment. Many of their boats were lost to accidental fires and I can only marvel at their bravery to have them launched while over one's head, never knowing if they were going to explode in their tubes. - Unlike the US, who ejected their missiles with compressed air before the solid fuel rockets motors ignited once they broached the surface. Worse yet, they had to surface to launch, which is tactically unsound. We quickly developed Polaris to launch submerged, making our Regulus cruise missile-equipped boats obsolete.
                  As stated, the Whiskey Long Bins were likely the most ugly submarines ever to put to sea, but the Soviets were compelled to do whatever it took to attempt to keep up. What they lacked in looks, they made up for in numbers, knowing most didn't have a chance. The Walker spy ring confirmed their worst fears about our acoustic advantage, and by the 80's most of their diesel fleet was a distant memory.
                    • 1121
                    Wow! Thank you both, Gantu and CC Clarke, for the footage and the background!
                    Personally, i very much like the long bin's look...
                    Gantu, i have got all of those pictures already, so sad, the beautiful detailed hand-drawn plan is wrong.
                    BUT i ran several photos through picture enhancement software and got THIS:
ID:	190404 Click image for larger version
ID:	190403 Click image for larger version
Name:	image_20950_Nero_AI_Image_Upscaler_Photo_Face_Nero_AI_Image_Denoiser_Nero_AI_Image_Upscaler_Photo_Face_copy_3163x2113.jpg
ID:	190402 Click image for larger version
                      • 1121
                      I do now have a good idea of how the sailbridge looked like.
                      also, there are some differences beetween the first two converted whiskeys, which had the misdile section inserted, and the later 6 boats that were built to 665' specs from keel.
                      i will build S-142/ 570 on the conning, in dark-grey and red scheme. That boat visited the GDR once and i even have got high-res colour pictures of her parading at Leningrad from the mid-60s.
                      Opened Up the floodholes beneath the fwd planes today and started to correct the shape of the torpedo tubes. Forward deck is now level without filling.
ID:	190411 Click image for larger version
ID:	190409 Click image for larger version
ID:	190410 Click image for larger version
ID:	190412 Click image for larger version
ID:	190413 Click image for larger version
ID:	190414 Click image for larger version
                        • 1121
                        Another try to have the high-res pictures:
ID:	190418 Click image for larger version
ID:	190419 Click image for larger version
ID:	190420 Click image for larger version
ID:	190421 Click image for larger version
ID:	190422 Click image for larger version
ID:	190423 Click image for larger version
ID:	190424 Click image for larger version
ID:	190425 Click image for larger version
ID:	190426 Click image for larger version
                          • 1121
                          This is the sail bridge. I think i got as close as possible.
                          i believe the sail on my kit should be flatter and longer, its siluette courve is to pointy...
ID:	190438 Click image for larger version
ID:	190437 Click image for larger version
ID:	190436 Click image for larger version
ID:	190435 Click image for larger version
ID:	190434 Click image for larger version
ID:	190433 Click image for larger version
ID:	190432 Click image for larger version
ID:	190431 Click image for larger version
                            • 1121
                            Enough for today!
                            Click image for larger version  Name:	20250913_223744_copy_2040x1148.jpg Views:	5 Size:	49.3 KB ID:	190449 Click image for larger version  Name:	20250913_223731_copy_1148x2040.jpg Views:	5 Size:	59.9 KB ID:	190448 Click image for larger version  Name:	20250913_223725_copy_1148x2040.jpg Views:	5 Size:	64.4 KB ID:	190447
                            • gantu
                              • 428
                              some more pictures
                              Regards Gantu
                                He's put some glass into that hull, reckon you could knock fence posts in with it!
