Scratch build Skipjack-conversion : Project 1710 Beluga in 1/63 scale
  • DrSchmidt
    • Apr 2014
    • 1322
    Jupp....you'll have to get the antenna outside. I flew F3E planes and they hat carbon fiber fuselages. They blocked the radio signal not only when the antenna was inside but also when it was outside but the fuselage came in between the transmitter and the antenna...
      • Oct 2017
      • 986
      I could try to use the safety rails as an antenna i suppose!
      am confident ill find a solution, but will keep you updated!
      I believe that to be the reason for the maker of the kit to sell it, because otherwise the carbon layup is superb, certainly the best i have ever seen. Outside mirror-like gelcoat, inside hard and rough weave, wall thickness 2mm all around...
        • Oct 2017
        • 986
        A little progress: i finished milling out the hollow grooves at the fins for fitting the planes - i should have included that in the master a long time ago! Started to invidualize the rudder as well, made the lower rudder.
ID:	165359Click image for larger version
ID:	165360Click image for larger version
ID:	165361Click image for larger version
ID:	165358Click image for larger version
        • Davidh
          • Nov 2010
          • 719
          Beautiful work Joerg. So nice. This hull is going to snap together beautifully.
          Dave.
            • Oct 2017
            • 986
            Thank you! Slow progress today: Installation of the plane bushings.
            3mm brass rod was cut to length and glued into the fins with CA. To do so, i drilled a tiny hole into each opening from one side of the fin, cleaned everything with alcohol and used a steel rod to align the bushings. Once properly placed, i injected the CA through the small holes. This saved me from having to hurry before the glue was cured and kept my fingers clean!
ID:	165430Click image for larger version
ID:	165429Click image for larger version
ID:	165425Click image for larger version
ID:	165428Click image for larger version
ID:	165427Click image for larger version
              • Oct 2017
              • 986
ID:	165466Click image for larger version
ID:	165467Click image for larger version
ID:	165468Click image for larger version
ID:	165469Click image for larger version
              Yesterday: Installation of the fwd diveplanes and basic filling of the transition from the old hull to the new stern cone.
              Jörg
              • neitosub
                • Nov 2021
                • 150
                Looks great Jörg! Makes me want to do this conversion to my Moebius Skipjack!
                  • Oct 2017
                  • 986
                  Thank you! That might be possible! I tried that with one of mine kits but went for the crp hull instead
                  • Bob Gato
                    • 873
                    A good side to carbon fiber on a model sub (besides its light weight and strength) is that the hull is conductive and can be used as a faraday cage to block unwanted stray signals creeping into your wiring and metal work-just ground it to the battery negative wire with a conductive epoxy...BG
                    • wlambing
                      • Nov 2020
                      • 382
                      Are you not going to use a "periscope" so you can see where you're going? Make a 'scope into antenna and go with that. You'll be able to watch the wake from the scope and it will look much better. Modern naval submarines (even old ones) don't drive around with railings or lifelines installed. I don't recall seeing any rails on Beluga, and I think only a rudimentary lifeline topside, for inport.
                        • Oct 2017
                        • 986
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_37.jpg
                        hi, we are talking about different things. I am referring to the safety rails port starbord of the deck, not the "fence" for in-port time.
                        Jörg
                        • gantu
                          • 387
                          Hier noc eine andere Ansicht.
                          Regards Gantu
                            • Oct 2017
                            • 986
                            Danke Dir! Das toppe ich!
ID:	165505Click image for larger version
ID:	165506Click image for larger version
ID:	165507Click image for larger version
ID:	165508Click image for larger version
ID:	165509Click image for larger version
ID:	165510Click image for larger version
ID:	165511Click image for larger version
ID:	165512Click image for larger version
                            • gantu
                              • 387
                              Noch eins
                              Regards Gantu
                                • Oct 2017
                                • 986
                                #30
                                Not bad...
                                some more goodies
                                Click image for larger version  Name:	1638958137_19-hdpic-club-p-podvodnaya-lodka-pr-1710-21.jpg Views:	0 Size:	65.1 KB ID:	165519Click image for larger version  Name:	1638958181_6-hdpic-club-p-podvodnaya-lodka-pr-1710-6.jpg Views:	0 Size:	46.8 KB ID:	165520Click image for larger version  Name:	1638958203_4-hdpic-club-p-podvodnaya-lodka-pr-1710-4.jpg Views:	0 Size:	48.4 KB ID:	165521Click image for larger version  Name:	4N9wn.jpg Views:	0 Size:	67.4 KB ID:	165522Click image for larger version  Name:	1638958212_30-hdpic-club-p-podvodnaya-lodka-pr-1710-32.jpg Views:	0 Size:	57.4 KB ID:	165523Click image for larger version  Name:	1638958175_5-hdpic-club-p-podvodnaya-lodka-pr-1710-5.jpg Views:	0 Size:	49.3 KB ID:	165524Click image for larger version  Name:	mVNDD.jpg Views:	0 Size:	68.9 KB ID:	165525Click image for larger version  Name:	1638958197_20-hdpic-club-p-podvodnaya-lodka-pr-1710-22.png Views:	0 Size:	24.1 KB ID:	165526Click image for larger version  Name:	1638958144_2-hdpic-club-p-podvodnaya-lodka-pr-1710-2.jpg Views:	0 Size:	50.1 KB ID:	165527
