Name:	images (16).jpeg
ID:	148265 when are you going to put her in the water?
      • Jan 2020
      • 1035
      #122
      Working on Trims in trimming tank today, fingers crossed!
        • Jan 2020
        • 1035
        #123
        Trimming is close, need to raise the stern a bit. Click image for larger version
          • Jan 2020
          • 1035
          #124
          Actually, submerged trim is next and I won’t raise the stern as after submerge she is level. Since I driver her in salt water she will sit a bit higher surfaced.
            • Jan 2020
            • 1035
            #125
            One note, yesterday I exprienced a small water leak. After re greasing the O’rings still leaked. Today I removed the O’rings and discovered one was dabbed with what seemed to be a tiny bit of adhesive…. I removed what I could, re greased and all seems good now. I will be replacing with a new seal to be safe. No electronic damage was incurred.
              • Jan 2020
              • 1035
              #126
              She is fully trimmed, surprisingly stable, we shall see when she is transported to my sub compound……. Click image for larger version
                • Jan 2020
                • 1035
                #127
                Meanwhile, time to paint. Will be using an Airbrush for the first time!
                  • 2041
                  #128
                  Beautiful build! Looking forward to wet-trials.
                  I like to point out that the 2.4GHz is suitable for both fresh and salt water. The more I play with the high frequency radios, the more I like them. My latest Vanguard build will have a 2.4 system in it.
                    • Jan 2020
                    • 1035
                    #129
                    Thanks Bob! It feels really good to be using 2.4GHz. So many options available for failsafes, trimming and ability to monitor onboard battery info. Your conversion info using RG-178 coax has been my bible and was spot on!! I cannot thank you, David and others enough for tutoring me as I have progressed in this new hobby wonderful hobby.
                      • Jan 2020
                      • 1035
                      #130
                      For you Bob, the 1.25” antenna : Click image for larger version
                        • Jan 2020
                        • 1035
                        #131
                        I created a groove in the dive planes cradle to hold the lighting and antenna wires to rest in place against the cylinder Click image for larger version
                          External battery? Doesn't the RCshipyard WTC already have provisions for 2 pairs of 18650 batteries, 2 for the pump and 2 for the drive motors/ servos?
                            • Jan 2020
                            • 1035
                            #133
                            No external batteries, out of curiosity why did you think that I indicated that?
                              I don't know, maybe the RED and BLACK wires?
                                • Jan 2020
                                • 1035
                                #135
                                Oh, those are for the LED navigation and rudder lights
