New Trumpeter Kilo 1:144 Build
  • biggsgolf
    • Jan 2020
    • 1028
    #46
    I see now. I used round rods, epoxy and baking soda attached lower halves first, checked for free movement then attached top halves. I am having trouble getting my head around the square tubes...
      • 13881
      #47
      The square rod rotates about as well as traditional round rod in the bearing surfaces; provides a 'flat' for the pushrod control-horn set-screw; and provides a 'flat' for the set-screw set within the stern plane/rudder holding the operating shaft firmly in place within the control surface.
ID:	147099Click image for larger version
ID:	147100Click image for larger version
ID:	147101Click image for larger version
ID:	147102Click image for larger version
ID:	147103Click image for larger version
ID:	147104Click image for larger version
ID:	147105Click image for larger version
ID:	147106Click image for larger version
      • biggsgolf
        • Jan 2020
        • 1028
        #48
        Beautiful! Oh the sub mechanics too!
        • biggsgolf
          • Jan 2020
          • 1028
          #49
          DavidM , I have received the castings from Bob in white metal. Do I file 1-4 and glue to 5 & 6, or do I solder? Sorry I am confused by them not being a single piece. Maybe my thinking is incorrect, please set me straight!
            • 2022
            #50
            You guys and your tiny boats. You're all crazy.
            • biggsgolf
              • Jan 2020
              • 1028
              #51
              Hahaha, well eventually I may invest in a larger scale then my 1:96 Blueback to sail in a lake or pond, but right now I only sail in my pool and the 1:96 does ok but a tight squeeze. I also want to try 1:144 for easier transporting to my home that has the pool in my tiny JCW Mini Cooper! Lol
                • 13881
                #52
                Looks familiar...
ID:	147246Click image for larger version
ID:	147247Click image for larger version
                  • 3637
                  #53
                  Biggsgolf did you also get the white metal props?
                  • biggsgolf
                    • Jan 2020
                    • 1028
                    #54
                    David, yes, I looked at those photos before asking how to assemble them. So I simply use aluminum tubes?
                    • biggsgolf
                      • Jan 2020
                      • 1028
                      #55
                      Yes Redboat, I did.
                        • 13881
                        #56
                        Yes. However it does not look like the Nautilus Drydocks has produced the cast metal parts hollow or pinned to accept aluminum tubes as I did with the original tooling and part production. I think you would be better off chopping off the snorkel head and boring it out for aluminum tubes, and scratch building the other antennas and scope heads and then mounting those to aluminum tube. Sorry.
ID:	147260Click image for larger version
ID:	147261Click image for larger version
ID:	147262Click image for larger version
ID:	147263Click image for larger version
                        • biggsgolf
                          • Jan 2020
                          • 1028
                          #57
                          Will do! Thanks
                          • biggsgolf
                            • Jan 2020
                            • 1028
                            #58
                            Magnet attached for removable sail
                            • biggsgolf
                              • Jan 2020
                              • 1028
                              #59
                              All magnets in place for screwless separation of the hulls and the sail. Very happy with the hull lines which match up almost perfectly, will make some minor adjustments. Recieved my driveshaft from Harbor Models which is beautiful and perfect for my Kilo. Waiting on some aluminum tubes to make the scooes and antennas.
                              • biggsgolf
                                • Jan 2020
                                • 1028
                                #60
                                After hull adustment
