    • 2735
Name:	images (16).jpeg
ID:	148265 when are you going to put her in the water?
      • Jan 2020
      • 720
      Working on Trims in trimming tank today, fingers crossed!
        • Jan 2020
        • 720
        Trimming is close, need to raise the stern a bit. Click image for larger version
          • Jan 2020
          • 720
          Actually, submerged trim is next and I won’t raise the stern as after submerge she is level. Since I driver her in salt water she will sit a bit higher surfaced.
            • Jan 2020
            • 720
            One note, yesterday I exprienced a small water leak. After re greasing the O’rings still leaked. Today I removed the O’rings and discovered one was dabbed with what seemed to be a tiny bit of adhesive…. I removed what I could, re greased and all seems good now. I will be replacing with a new seal to be safe. No electronic damage was incurred.
              • Jan 2020
              • 720
              She is fully trimmed, surprisingly stable, we shall see when she is transported to my sub compound……. Click image for larger version
                • Jan 2020
                • 720
                Meanwhile, time to paint. Will be using an Airbrush for the first time!
                  • 1768
                  Beautiful build! Looking forward to wet-trials.
                  I like to point out that the 2.4GHz is suitable for both fresh and salt water. The more I play with the high frequency radios, the more I like them. My latest Vanguard build will have a 2.4 system in it.
                    • Jan 2020
                    • 720
                    Thanks Bob! It feels really good to be using 2.4GHz. So many options available for failsafes, trimming and ability to monitor onboard battery info. Your conversion info using RG-178 coax has been my bible and was spot on!! I cannot thank you, David and others enough for tutoring me as I have progressed in this new hobby wonderful hobby.
                      • Jan 2020
                      • 720
                      For you Bob, the 1.25” antenna : Click image for larger version
                        • Jan 2020
                        • 720
                        I created a groove in the dive planes cradle to hold the lighting and antenna wires to rest in place against the cylinder Click image for larger version
                          • 2735
                          External battery? Doesn't the RCshipyard WTC already have provisions for 2 pairs of 18650 batteries, 2 for the pump and 2 for the drive motors/ servos?
                            • Jan 2020
                            • 720
                            No external batteries, out of curiosity why did you think that I indicated that?
                              • 2735
                              I don't know, maybe the RED and BLACK wires?
                                • Jan 2020
                                • 720
                                Oh, those are for the LED navigation and rudder lights
