    • Jan 2020
    • 1028
    Trying something new! This is a 1:144 Kilo build. The Cylinder arrived from overseas today! Since my pool is 40’x20’ I have been looking for a smaller scale sub. My 1:96 scale Blueback does well, but not as nimble as this should be. Updates to follow!
    • Jan 2020
    • 1028
      • 13878
      Some 1/144 KILO eye-candy in the form of stills.
ID:	145794Click image for larger version
ID:	145795Click image for larger version
ID:	145796Click image for larger version
ID:	145797Click image for larger version
ID:	145798Click image for larger version
ID:	145799Click image for larger version
ID:	145800Click image for larger version
ID:	145801Click image for larger version
ID:	145802Click image for larger version
ID:	145803Click image for larger version
ID:	145804Click image for larger version
      And some bonus video of a SWM 1/96 KILO: https://youtu.be/W9Pg0zGb5Wo
      • coryhenry
        • Jul 2020
        • 156
        That is quite a production line of Kilo's, what year was that?
          • Jan 2020
          • 1028
          Ahhhh, thanks for the eye candy!
            • 13878
            about 15 years ago?
              • 3635
              Biggsgolf,
              If I'm not mistaken that's an rcShipyard WTC with a peristaltic pump- water bag ballast system.
              Website: https://www.rcshipyard.com/shipyard/.
              Are you using the kits stock parts i.e. dive planes and rudder or do you have David's resin fitting kit for the Kilo?
                • Jan 2020
                • 1028
                I am using the rcshipyard fittings kits for the Kilo and the Soryu. I oredered the Kilo Cylinder set up, and the Soryu Cylinder unassembled.
                  • Jan 2020
                  • 1028
                  I have found very few 1:144 kits. I guess I am in the minority since so far I only drive the subs in my pool, no lakes etc. May do that after I am more exprienced....
                    • Jan 2020
                    • 1028
                    1:144 Soryu Kit Unassembled
                      • Jan 2020
                      • 1028
                      Received my Scimitar blades today, one for the Kilo and one for the Soryu!
                        • 3635
                        Not sure about the Soryu's prop but the Kilo's hub is rounded with 4 vortex attenuator blades in a + pattern.
                          • 13878
                          This what the domestic and foreign propellers look like for that boat:
ID:	146896Click image for larger version
ID:	146897Click image for larger version
ID:	146898Click image for larger version
ID:	146899Click image for larger version
ID:	146900Click image for larger version
                            • Jan 2020
                            • 1028
                            Well, looks like I got bad intel, back to square one I go........ thanks guys for the call outs. Any good sources for the correct props in 3/4”, 1”, both 2MM bore with set screw?
                              • Jan 2020
                              • 1028
                              Starting my 1:144 Kilo
