    • 13859
    #181
    He Who Shall Not Be Named : Unless the batteries were of fundamentally different kind on US boats, I guess the electricians made a bit fun of you. In the XXIII each cell had 4 volts, 31 about 120 Volts at the end of the lines. 120 Volts don't kill you. The cells are connected in series, so when you bridge two neighboring cell lines you will be exposed to 20-30 Volts. Even less scary. Or do I get something wrong?
    Of course, you're right.
    But, in my own defense, I was a dumb-ass kid who had just cross-decked from a Tender. I was regarded as only a new non-qualified-play toy to be ****ed with mercilessly till I got the smarts (it took me nine-long-months) to get a set of Dolphins slammed into my chest.
    • DrSchmidt
      • Apr 2014
      • 1369
      #182
      O.K., I get the atmosphere on the boats.....grat photo. I actually like the lantern in the back.
        • 1621
        #183
        Guys, DC is more dangerous as AC, if you short a battery, you have a inferno, when you do this and the end you've got 120 Volts DC, and a massive current wil fry you, probably shoes left only.
        Just my two cents.
          Looking good David!
          That had to be a very special day for you!
            • 13859
            #185
            Looking good David!
            followed by a drunken whirl that lasted three days. Ah... Duval Street! (Thank God for penicillin!)
            • DrSchmidt
              • Apr 2014
              • 1369
              #186
              Just my two cents.
              I agree, if you short a high power battery, it'll burn. But at 120 V your body won't be very effective at shorting a battery. 120V are potentially deadly but you're body has quite a high resistance.
                • 1621
                #187
                That's true, but if you short the busbar, it will give some nice firework, touching a busbar won't hurt you, even making connection with your body between two busbars won't give much trouble, as you stated, your body resistance is much too high to cause problems.
                • DrSchmidt
                  • Apr 2014
                  • 1369
                  #188
                  The most repetitive part of this built is done....the batteries are painted. Next will be cabling and ventilation piping....
                  • goshawk823
                    • Oct 2010
                    • 262
                    #189
                    Looking good David!
                    Wow David...you've had that torpedo tattoo for a long assed time.
                    • Monahan Steam Models
                      • 755
                      #190
                      The finished result of the battery painting looks great. You must have done it without any caffeine in your system. Tedious work.
                      • DrSchmidt
                        • Apr 2014
                        • 1369
                        #191
                        I cant't even remember my own name without caffeine... :D
                        • DrSchmidt
                          • Apr 2014
                          • 1369
                          #192
                          Little update...the racks in the storage compartment below the torpedo tubes are loaded:
                            • 755
                            #193
                            The details you are adding to your build are amazing and really bring it all to life. My hats off to you sir! Great stuff!
                              • 13859
                              #194
                              Yeah, Nick. The good Doctor had me entranced with his radio-shack. But, the dry-goods space, adjacent the battery well.... That blew me away! So much like the spaces on submarines and ships I served on. I found myself looking for rat droppings and bugs -- the display is that good!
                                • 1624
                                #195
                                If the inside is this good, the outside should be something to behold.
