Guys, DC is more dangerous as AC, if you short a battery, you have a inferno, when you do this and the end you've got 120 Volts DC, and a massive current wil fry you, probably shoes left only.
Just my two cents.
Manfred.I went undergroundComment
That had to be a very special day for you!
"Firemen can stand the heat"Comment
I agree, if you short a high power battery, it'll burn. But at 120 V your body won't be very effective at shorting a battery. 120V are potentially deadly but you're body has quite a high resistance.Comment
That's true, but if you short the busbar, it will give some nice firework, touching a busbar won't hurt you, even making connection with your body between two busbars won't give much trouble, as you stated, your body resistance is much too high to cause problems.
The finished result of the battery painting looks great. You must have done it without any caffeine in your system. Tedious work.Comment
The details you are adding to your build are amazing and really bring it all to life. My hats off to you sir! Great stuff!Comment
Yeah, Nick. The good Doctor had me entranced with his radio-shack. But, the dry-goods space, adjacent the battery well.... That blew me away! So much like the spaces on submarines and ships I served on. I found myself looking for rat droppings and bugs -- the display is that good!Who is John Galt?Comment
