November Holiday
    • 12289
    Originally posted by HardRock
    Looking very good Mr M. Inspiring as always.
    I get the same from your hull work on this project, Scott. Most inspiring, sir.
    I'll get to work on the SD for this thing. I'll do some geometry to work out the topside displacement. I assume the same wall thickness as the recent ALBACORE? I'll slap a prototype SD together with a bigger-than-needed ballast tank (God knows we have plenty of hull length to play with!).
    I'll also get to work on saddles, indexing pin-Velcro foundation and hull half indexing tabs. Anything else you can think I can provide from this end, Scott?
      Thanks Mate. There is one other thing that you could do if you have the time. The Russian make use of a swivel link on some of their subs. Its this thing here:
      I was thinking of making one up in brass but having done that I lack the expertese to cast it in white metal. Its such a prominent item that I don't think that it should be ignored.
        • 12289
        This old salvage diver thinks those were lifting fixtures. There has to be at least one other set aft on the hull. Two elements to each: a fixed padeye that makes up to a reinforced foundation that is welded to the inner hull, and the long link that will stand vertical over the padeye when tension is applied to the salvage gear (a heavy wire cable, part of a massive lifting bridle). I think the sets of these would be better produced using a vacuum resin casting process.
        However -- if I'm to get into fiddley work like this (WHICH I LOVE!) -- why not have me do the antennas, masts and scopes? If I do those fragile things then it would warrant a spin-casting tool for metal casting, and in that case, it's a good argument to indeed cast the lifting fixtures out of metal from the same ganged tool.
        This is, FUN!
        The Horrible
          I bow to your extensive knowledge and it would be great if you did the fiddly bits. And you right, it is fun!!!
            • 12289
            You chose wisely (any Indiana Jones fan's out there?.....). Give me the dimensions of those dumb-bell looking deck cavities.
            And who's got good dope on the antennas, scopes, and snorkel used on these boats?
            And I think it time for me to dust off the old masters I was working up for 1/96 crew. If we're gonna do this, lets do it right!
              • 12289
              OK, seeing that the 2.5" SD will loose about 20% of its displacement when in surfaced trim I want to affirm that your models waterline forward is between the lower line of the big sonar window and the top of the upper set of shutter doors and that after waterlines falls a bit over the upper edge of the rudder. Sound about right?
              • DMTNT
                • Jun 2018
                • 297
                Holy ****.......
                Also, David you may have already seen all of these, but here are a few photos I found online. Click image for larger version  Name:	35212647145_1c1003f4bd_z.jpg Views:	1 Size:	241.6 KB ID:	131035
                Click image for larger version  Name:	DrGCAksWoAEuqW5.jpg Views:	1 Size:	605.7 KB ID:	131042
                Click image for larger version  Name:	November Illustration.jpg Views:	1 Size:	79.1 KB ID:	131043
                Click image for larger version  Name:	5dc3792f313441b6b1948f8bcbb959d7.jpeg Views:	1 Size:	73.4 KB ID:	131036
                Click image for larger version  Name:	1e06d9017fad4dab3f7f1d99049ae0c8.jpg Views:	1 Size:	322.0 KB ID:	131037
                Click image for larger version  Name:	3_129565.jpg Views:	1 Size:	321.8 KB ID:	131044
                Click image for larger version  Name:	November ill 2.jpg Views:	1 Size:	18.0 KB ID:	131045
                Click image for larger version  Name:	masts.jpg Views:	1 Size:	237.0 KB ID:	131046
                I know these are models, so that doesn't mean squat in terms of accuracy, but still... Click image for larger version  Name:	7450_11-auto_downl.jpg Views:	3 Size:	53.4 KB ID:	131040
                Click image for larger version  Name:	p9112326.jpg Views:	1 Size:	158.4 KB ID:	131041
                Do you have any editions of Guide to the Soviet Navy by Norman Polmar? Published throughout the 80's in at least 5 editions. Let me know if you don't and I'll get you hooked up.
                Dead men tell no tales...
                  The indentations are two 5mm circles set 10mm centre to centre at present, but I can easily modify them to whatever size you think is appropriate.
                    Some mast photographs;
Name:	29-3933077-2-watermark-5143b9cd7efa6e6b37307b2c-108-24-10-10-se copy.jpeg
Name:	627-November akterskeppp från torn-131215 copy.png
                      • 12289
                      OK. Good for starters, Scott. I'm on it.
                        • 12289
                        [QUOTE=HardRock;n131048]Some mast photographs;
                        Good stuff, I just filed them away. Thanks, Scott. Snoop-tray radar, and quad-DF I got (from the recent 1/96 KILO work), All others I need to make.
                        Get me a sail asap so I can work up the mast foundation, bridge, and SAS snorkel.
                          Will do. Rough but ready!
                          • Davidh
                            • Nov 2010
                            • 719
                            Hey Scott,
                            I was looking over the other forums and found a pic of Luke Foley. I didn’t know he’d taken up RC subs since leaving State politics..... Apologies to Bob Gaito. (AMA east hobby show) Bob , you just happen to be the spitting image of an ex New south Wales pollie!
                            Great pic. By the way.
                            • Tirfing
                              • Jan 2017
                              • 66
ID:	131075 Sail of one of the sisters as a memorial.An ESM (peapot) i believe.
                                • 12289
                                Good catch. Thank you, sir.
