November Holiday
    я замерзаю
    • DMTNT
      • Jun 2018
      • 297
      #212
      Originally posted by HardRock
      я замерзаю
      Come Volya, the steam from the reactors will warm you up in no time.
      Dead men tell no tales...
        Making a start of fixing the etched pieces to the deck. I'm not entirely sure how this is going to look in the end. Some of those holes are really small.
        • DMTNT
          • Jun 2018
          • 297
          #214
          Speaking from total ignorance here, as I have never laid up anything, but might it be worth it to just mark their locations and install the PE components on a completed hull?
            Yeh, but no. The problem is that the brass bits fall off with use in a watery environment. The idea is to capture the detail in epoxy resin that will be impervious to all the external crap that will undoubtedly be thrown at it. Also means that I only have to make one set of brass bits.
            On a different track: I love your dog. I live on a farm and I can tell you that "that" dog is a hunter; as for the **** eating grin on his owner, well that's another story.
            • Tirfing
              • Jan 2017
              • 66
              #216
              theClick image for larger version
ID:	130968 Concerning the circular pattern of holes on the front of the sail; they might be some sort of pressure sensor. For what purpose I do not know. This Picture (with the happy blokes) is the only I could find. Sorry for not delivering better info.
                • 1088
                #217
                Great picture!from where did you get it, fredrik?
                  • 13948
                  #218
                  As an r/c model submarine suffers extremes of temperature rapidly -- the July sun baking the model as it sits on the bench, to the relatively cold water when you plunk it into the drink for another run -- you want as much of the structure to be homogeneous as possible. The ideal is a structure where all surfaces have the same expansion/shrinkage rate. Not so with GRP with brass or stainless inserts, or GRP with polystyrene sheeting applied (ain't that right John?!). The more unlike materials you have butted up against one another, the more likelihood of cracks and peeling of substrate over time.
                  If all that inlay work Scott's putting into his master eventually becomes part of the GRP hull and sail part matrix, then that's the ideal. No cracking, peeling, or widening seams down the road, and an easier assembly job for the end-user.
                  I HAVE SPOKEN!!! ….. SO LET IT BE WRITTEN!!!!!!!!
                  • Tirfing
                    • Jan 2017
                    • 66
                    #219
                    Hello Jörg, I got the Picture from a friend who is now dead. His name was also Fredrik
                      If in doubt, add more brass.
                        • 13948
                        #221
                          • 13948
                          #222
                            Looking very good Mr M. Inspiring as always.
                              Spent a lazy afternoon putting tiny pieces of brass into tiny indentations. Its a bit rough around the edges but this is a Russian sub after all!
                              • DMTNT
                                • Jun 2018
                                • 297
                                #225
                                Hit it with a hammer, and if that does not fix it... hit it some more!
