November Holiday
  • Davidh
    • 719
    #286
    I’ll second that. Several times I’ve mixed up too much silicon and it’s had to go to waste.
    I’m also stealing.....
    david h
      • 3757
      #287
      Ditto here too! Saving pictures as I type.
        • 2641
        #288
        You can make a risotto afterwards.
          Yum, yum. Silicon risotto!
            • 13982
            #290
            david h
            Well you're stealing from the best. I stole the rice trick from a local model boat seminar presenter. Likely has saved me at least a thousand-dollars of wasted rubber and resin over the years.
              • 13982
              #291
              • DMTNT
                • Jun 2018
                • 297
                #292
                Incredible watching this all come to life, you guys. Fine work.
                Dead men tell no tales...
                  • 13982
                  #293
                  This is the most fun I've had with my clothes on in a long time!
                    • 13982
                    #294
                      • 3757
                      #295
                      more info, this is great. The third from last, is the clear silicon to seal the smaller tube to your mold? That tube is to get more weight or casting metal up high?
                      last photo is showing what? Coating with epoxy to make thin shells?
                      really good stuff you are showing, thank you for taking the time to do this!
                      peace,
                      tom
                        And there's yet another mental image that I can't unremember!
                          • 1100
                          #297
                          That chocolate-sail looks tasty
                            • 13982
                            #298
                            A good brain scrubbing with Drano should do it.
                              • 13982
                              #299
                                • 2641
                                #300
                                In the picture of the sail moulds you're sanding the laminate in the tool with the Dremel tool. I take it the rubber is flexible enough to give way as you get near the line?
