I get the same from your hull work on this project, Scott. Most inspiring, sir.
I'll get to work on the SD for this thing. I'll do some geometry to work out the topside displacement. I assume the same wall thickness as the recent ALBACORE? I'll slap a prototype SD together with a bigger-than-needed ballast tank (God knows we have plenty of hull length to play with!).
I'll also get to work on saddles, indexing pin-Velcro foundation and hull half indexing tabs. Anything else you can think I can provide from this end, Scott?
