A Skipjack in Ireland
  • The Boattrainman
    • Mar 2016
    • 443
    #211
    The Piston Tank outlet hose sits neatly around the motor and between the servos.
    Click image for larger version  Name:	IMG_0899 (800x600).jpg Views:	1 Size:	293.3 KB ID:	120366
    Bits of square plastic tubing and channel are used to make fixings for the permanent 12V wiring, and holder for a spare fuse is made.
    Click image for larger version  Name:	IMG_0902 (800x600).jpg Views:	1 Size:	256.8 KB ID:	120368Click image for larger version  Name:	IMG_0903 (800x600).jpg Views:	1 Size:	244.9 KB ID:	120369
    A short additional support rod is used as the lower one is missing to allow the motor to be taken in/out. Around this bar the wiring to the end cap for the lights will be wrapped and down the square plastic rod.
    Click image for larger version  Name:	image_34566.jpg Views:	1 Size:	274.4 KB ID:	120370
    On the servo lead side a series of double holes are drilled to take mini cable ties.
    Click image for larger version  Name:	image_34565.jpg Views:	1 Size:	276.5 KB ID:	120367
    The Boattrainman
    • The Boattrainman
      • Mar 2016
      • 443
      #212
      Progress has slowed, not because there is any less work being done, but because I'm painting the tech rack. As I spray slowly and leave 24 hours between coats it's time consuming.
      Click image for larger version  Name:	IMG_0905 (800x600).jpg Views:	1 Size:	270.5 KB ID:	120552
      Paint is a basic automotive spray primer, same colour as the plastic, just to cover up blemishes and filler.
      The final 12V item is the switch to turn off the lights when diving, it'll be covered by the piston tank switch.
      Click image for larger version  Name:	IMG_0907 (800x600).jpg Views:	1 Size:	251.9 KB ID:	120553
      Here is the switch outside the housing, the roller arm is depressed as the piston spindle moves outward. By wiring a standard SPDT Push to Make microswitch with the 'On' side when the arm is not depressed, when it is depressed it switches to the unwired side, making it a Push to Break switch.
      Click image for larger version  Name:	IMG_0909 (800x600).jpg Views:	1 Size:	219.3 KB ID:	120554
      The Boattrainman
      • The Boattrainman
        • Mar 2016
        • 443
        #213
        The wiring continues, every wire is being custom cut,including the servo leads, to the exact length, I'll post only when it's all done
        However, a previous post about water leeching up the external wiring bit me on the ass! During pressure tests with the Piston Tank installed, the only air escaping was out the leads to the lights...................Incredible.
        To remedy this,I tried an external compression fitting, using a connector and small brass inserts to squeeze the wires.
        Click image for larger version  Name:	IMG_0912 (800x600).jpg Views:	1 Size:	254.9 KB ID:	120734Click image for larger version  Name:	IMG_0913 (800x600).jpg Views:	1 Size:	230.2 KB ID:	120735
        Click image for larger version  Name:	IMG_0915 (800x600).jpg Views:	1 Size:	243.3 KB ID:	120736
        It didn't work!!!!!
        So I resorted to my usual plastic surround making a small box filled with epoxy, this time inside the WTC.
        Click image for larger version  Name:	IMG_0917 (800x600).jpg Views:	1 Size:	285.8 KB ID:	120737
        The four leads are soldered to two wires leaving the box.
        Click image for larger version  Name:	IMG_0920 (800x600).jpg Views:	1 Size:	241.8 KB ID:	120738
        This is the finished box, with cables soldered to the bare wires running back to the lights switch.
        The Boattrainman
          Nice and Tidy. My wiring is usually a mess(rats nest).
          • The Boattrainman
            • Mar 2016
            • 443
            #215
            I'm closing in on the final part of the wiring but I have a question.
            To get the Receiver aerial from inside the WTC to the outside (and hopefull up the inside of the sail), there are two options.
            1. Drill a small hole in the end cap, lead the aerial out the hole and seal as usual with epoxy. That means the reciever and aerial are mated to that end cap.
            2. Drill a small hole in the end cap, push a small length of brass wire (the same diameter as the inner core of the Reciever aerial) through the hole, cut the aerial short in the WTC and attached a single pin connector to inner aerial to push onto the wire ,and solder the outer piece of aerial to the outer piece of wire. As long as inner piece of aerial, PLUS brass wire PLUS longer piece of outer aerial come to the same length as the original whole aerial it should work?????
            I know, I know the web is full of posts 'never ever cut, shorten, lengthen a receiver aerial, etc. etc. But if I get this to the mm, it should work. And I get that the aerial length is a mathematical factor of the transmission frequency, but if it all ends up the same length, what's the diff?
            Or am I missing something.
            The Boatrainman
              • 3735
              #216
              I used to use #2, but I would sometimes get funny reception. Now all my subs have the antenna left inside the tube. No issues. Someone else who periodically runs in brackish water would leave his antenna full length in the cylinder then using option 2 and whatever went outside the sub was just additional. His subs run amazingly well.
                • 13948
                #217
                The Boatrainman
                Antennas on the bands we use (the exception is that god-awful 2.4gHz) are of the fractional type -- ideal length is too long to burden transmitter or receiver. But antennas at a harmonics of the full wave work just fine, and that's what comes in the box. So, fine if shortened a bit. You'll still get enough signal to the detector part of the circuit to be useful. So, cut away and don't sweat it. Another thing -- we don't come close to exploiting the ideal range on this gear. We bubble-heads typically consider 150-feet away a long way off -- we're not sending a drone a mile down range here! To us the inverse-square-law is our friend.
                • The Boattrainman
                  • Mar 2016
                  • 443
                  #218
                  Thanks guys!
                  Another expense I hadn't factored was my 2.4Ghz Trans was redundent for this build. I'm sorry now I let my lovely 6-channel 40Mhz Hitec unit go when I sold my U-203, 40Mhz stuff almost impossible to find now.
                  I eventually found a second-hand Trans in a local model shop, they let me have it for 40 Euro, a bargain I suppose. It's a Futaba T6EXAP and is the last model before they switched to 2.4Ghz and using the same Trans design, looks like it was never used...............120 bucks when first came out but redundent within a few months.
                  What was wrong with 35mhz, 40mhz and 72mhz (in the USA), I actually enjoyed fecking around with crystalsl!!!!
                  That said, my FlySky 2.4Ghz was also a bargain, at 50 Euro brand new with matched Receiver and fully programmable..........time marches on............!
                  • The Boattrainman
                    • Mar 2016
                    • 443
                    #219
                    Some form of heat insulation/shield is needed around the ESC. This small aluminium plate is made to go under and keep the ESC away from plastic parts.
Name:	IMG_0922 (800x600).jpg
ID:	120812Click image for larger version
Name:	IMG_0923 (800x600).jpg
                    The Boattrainman
                    • The Boattrainman
                      • Mar 2016
                      • 443
                      #220
                      Following on from the advice about the Receiver aerial here is the build. The total length of the aerial is 985mm, so I have to re-create that.
                      A 1.5mm hole is drilled in the end cap and a small plastic tube is glued to the outside and filled with epoxy, and has a 1.5mm pin pushed into it which is pre-soldered to an 800mm length of the aerial.
                      Click image for larger version  Name:	IMG_0925 (800x600).jpg Views:	1 Size:	225.5 KB ID:	120816
                      Click image for larger version  Name:	image_34685.jpg Views:	1 Size:	204.7 KB ID:	120817
                      The small plastic tube gets an end cap, and the pin inside a small washer to finish it off.
                      Click image for larger version  Name:	IMG_0931 (800x600).jpg Views:	1 Size:	238.6 KB ID:	120818Click image for larger version  Name:	IMG_0932 (800x600).jpg Views:	1 Size:	234.3 KB ID:	120819
                      The small piece of aerial still attached to the Receiver, gets a connector made from a 2.5mm brass tube, small piece of heat shrink and a plastic cover from mains cable.
                      Click image for larger version  Name:	IMG_0934 (800x600).jpg Views:	1 Size:	248.3 KB ID:	120820
                      The entire length of the aerial inside PLUS connector PLUS end cap pin PLUS external piece of aerial is still 985mm, and receives signals from the Transmitter just fine.
                      Click image for larger version  Name:	IMG_0935 (800x600).jpg Views:	1 Size:	248.5 KB ID:	120821
                      And that is the last hole to be drilled in the end caps (6 in the aft cap and 3 in the fore cap)!!! Each time you sweat that a new hole will leak and ruin the build, glad that's over.
                      Just waiting for a main drive battery and some final parts and I can finish the wiring,then the WTC will be operational.
                      The Boattrainman
                      • The Boattrainman
                        • Mar 2016
                        • 443
                        #221
                        The wiring is now sorted, five weeks including de-bugging and a faulty pitch controller.
                        It took a lot longer than expected also as both wire ends (on over 100 wire pieces) are tinned with solder, and all soldered connections have a heat shrink sleeve.
                        Starting at the forward end, the 12V power is taken from the battery box with a Deans plug. The box can hold an 11.2V 5000mah Lipo, or a ten-cell 12V 3000mah Nimh block, will be testing both.
                        Click image for larger version  Name:	IMG_0936 (800x600).jpg Views:	1 Size:	248.8 KB ID:	120860
                        The power is led up to the fuse box and main switch and to a connector block with one connector each for the motor ESC, Piston Tank Switch and navigation lights. The light switch is just visible under the piston tank switch.
                        Click image for larger version  Name:	IMG_0939 (800x600).jpg Views:	1 Size:	299.3 KB ID:	120862
                        Wiring passes the piston tank through a square plastic tube and to the lights along the upper strengthening rod, and into another four connector block (2 for 12v power in, and 2 to the motor under).
                        Click image for larger version  Name:	image_34702.jpg Views:	1 Size:	270.8 KB ID:	120863
                        The space for the ESC has the heat shield and a connector to the Receiver ready to take the plug. The screws on the top are holding the motor mount under this box.
                        Click image for larger version  Name:	image_34704.jpg Views:	2 Size:	272.7 KB ID:	120875
                        This is the underside of the above, the motor is upside down and retains it's Tamiya plug so it can be swopped out, twin cable ties keep the wiring off the motor in case it heats.
                        Click image for larger version  Name:	IMG_0945 (800x600).jpg Views:	1 Size:	274.0 KB ID:	120867
                        On the servo lead side, there is a space for the Engel piitch controller beside the dive plane servo (the unit is gone back to Engel as it's 'twitching' the servo, numerous tests with other servos etc. proves the unit is faulty).
                        Click image for larger version  Name:	IMG_0941 (800x600).jpg Views:	1 Size:	269.5 KB ID:	120868
                        The servo leads pass the piston tank in pairs, held in place by heat shrink sleeve and a plastic keeper stuck to the piston tank with double-sided tape.
                        Click image for larger version  Name:	IMG_0943 (800x600).jpg Views:	1 Size:	284.5 KB ID:	120865
                        The servo leads are led by the main switch etc. through two tunnels and a piece of heat shrink, all servo leads custom cut to length.
                        Click image for larger version  Name:	image_34706.jpg Views:	1 Size:	311.3 KB ID:	120866
                        The Receiver is held in place by three L-shaped pieces of plastic, the push rod to the outer part of the main switch has a bit of Bowden cable as a cover.
                        Click image for larger version  Name:	image_34700.jpg Views:	1 Size:	292.8 KB ID:	120861
                        There are two universal couplings, one at each end of the stuffing tube, and each has a compressed O-ring and thrust washer.
                        Click image for larger version  Name:	image_34708.jpg Views:	1 Size:	263.4 KB ID:	120869
                        Click image for larger version  Name:	IMG_0948 (800x600).jpg Views:	1 Size:	256.8 KB ID:	120874
                        And it all fits snuggly into the WTC. All 12V on the starboard side and all servo wiring on the port side, with both motors having suppression capacitors that should stop any interference to the Receiver. Click image for larger version  Name:	image_34710.jpg Views:	1 Size:	304.9 KB ID:	120871
                        The Boattrainman
                        • reddevil
                          • Jun 2009
                          • 346
                          #222
                          Really impressive. Congratulations.
                          • The Boattrainman
                            • Mar 2016
                            • 443
                            #223
                            Thanks Reddevil.
                            This little fitting will help keep the wiring tidy outside the WTC.
Name:	IMG_0950 (800x600).jpg
                            I sourced automotive waterproof connectors (from 12v Planet) to join to both the sail lights and solitary tail light, a bit big for a small model but worth it.
Name:	IMG_0952 (800x600).jpg
ID:	120934Click image for larger version
Name:	IMG_0951 (800x600).jpg
                            The plugs are held down to the bottom of the hull out of the way of the push rods and prop shaft.
Name:	IMG_0953 (800x600).jpg
                            The Boattrainman
                            • The Boattrainman
                              • Mar 2016
                              • 443
                              #224
                              Another update on costs:-
                              The basic WTC is detailed earlier at 103 Euro.
                              Going left to right on the large picture above:-
                              WTC..........................103
                              Battery.........................25 Hobbyking
                              Receiver........................8 Ebay, used
                              Piston Tank Switch.....59 Engel
                              Piston Tank...............175 Engel
                              Lights switch..................6 RS Radionics
                              12V Motor....................33 Ebay
                              Elec Speed Cont..........30 Cornwall Model Boats
                              3 X Small Servos..........24 Hobbyking
                              Pitch Controller............79 Engel
                              2 X Couplings..............18 Cornwall ModelBoats
                              2 X Connectors............14 12V Planet
                              Servo leads..................10 Local Model Shop
                              4 X Rubber Bellows......16 Cornwall Model Boats
                              Total.............................599
                              Wiring of various gauges, brass/steel rods, small connector blocks, plastic tubing, screws, fuse, main switch, heat shrink, glue, solder and sanding materials, I had in stock.
                              With the cost of two kits (I had to acquire a second as I was unhappy with the sail on the original) at 128 and Caswell Fittings at 150, the grand total looks to be coming in under 900 Euro, with only paint and ballast materials to be sought.
                              Not bad value for a fully working static(hopefully) diving sub, and a good test bed for future models.
                              All of the suppliers mentioned were excellent except for one delay from Hobbyking, I have to commend both Cornwall Model Boats and Caswell (now Nautilus Drydocks) for the quality of items and back up service.
                              On to the WTC shakedown and system test.
                              The Boattrainman
                              • The Boattrainman
                                • Mar 2016
                                • 443
                                #225
                                There are three parts to trimming the model, surface major trim, surface sub-trim and submerged trim.
                                7mm X 20mm metal bar is cut to various lengths and laid along the keel. I've seen a lot of boats/subs trimmed with large pieces of lead or metal usually bunched up in one place, this is a mistake as it creates a 'moment' around which the boat will bob. To counter this, the bars are laid along the keel as close to the bottom as possible all along the line of the keel but not fouling the water inlets/gratings.
                                Click image for larger version  Name:	IMG_0955 (800x600).jpg Views:	1 Size:	304.5 KB ID:	120966Click image for larger version  Name:	IMG_0960 (800x600).jpg Views:	1 Size:	263.3 KB ID:	120969
                                Click image for larger version  Name:	IMG_0959 (800x600).jpg Views:	1 Size:	292.6 KB ID:	120970
                                The bars are moved around to get the sub level, and here it sits in my test facility.
                                Now the eagle eyed will notice it's trimmed to slightly below the waterline as tests with a 500ml weight (below) slung to the bottom of the hull on the elastic band, simulating the 500ml piston tank volume/weight, demonstrate it needs to be a fraction low in the water to completely submerge.
                                Click image for larger version  Name:	IMG_0958 (800x600).jpg Views:	1 Size:	207.9 KB ID:	120968
                                On the plus side, sub-trim is not required as care with the building of the WTC and positioning of the heavy components plus accurate centreing of the WTC within the hull at the centre of gravity means it sits perfectly upright. Neither is any foam needed for flotation as the WTC provides all the buoyancy needed.
                                I'll work on the submerged trim when the piston tank is fully tested.
                                The Boattrainman
