A Skipjack in Ireland
  • Pawly
    • Jun 2013
    • 59
    #256
    Hi Rob,
    I would still run a separate BEC unless you know what the current draw is for your electronics and it comes in under what the ESC is capable of.
    I run a Castle Creations BEC 10.
    Regards
    Pawly
    • The Boattrainman
      • Mar 2016
      • 443
      #257
      Here is are some more shots of the painting progress. The gratings got a wash of mucky brown and light dry-brushing with off white and are a bit more defined.
      Click image for larger version  Name:	IMG_1017 (800x600).jpg Views:	1 Size:	247.5 KB ID:	121366Click image for larger version  Name:	IMG_1018 (800x600).jpg Views:	1 Size:	281.5 KB ID:	121367
      I've managed to darken down the grey a bit. Other than some salt washes, I'm not big into heavy weathering of my models.
      Click image for larger version  Name:	IMG_1019 (800x600).jpg Views:	2 Size:	314.0 KB ID:	121376
      The lights look fine, the top sail light is a bit small to be seen at distance.
      Click image for larger version  Name:	image_34900.jpg Views:	1 Size:	220.3 KB ID:	121374Click image for larger version  Name:	image_34898.jpg Views:	1 Size:	256.2 KB ID:	121369
      The five pieces of glass in the sail will have to wait till all the varnish coats are finished.
      The Boattrainman
      • The Boattrainman
        • Mar 2016
        • 443
        #258
        Getting some conflicting information, is this ESC suitable for the 11.1V LIPO Battery?
        I saw a website indicating that it is not LIPO 'safe' (whatever that means).
        The Boattrainman
        • Pawly
          • Jun 2013
          • 59
          #259
          Hi Boattrainman,
          That ESC is not for LIPO's. The LIPO battery will destroy the ESC. LIPO's can release a lot more energy than the NiMH or NiCad's can.
          You will need an Mtroniks TIO ESC to use with a LIPO. One of the two below will work with LIPO's.
          15A brushed RC boat speed controller for use in model boats 100% waterproof forwards and reverse throttle control
          or
          30A brushed RC boat speed controller for use in model boats 100% waterproof forwards and reverse throttle control
          Regards
          Pawly
          • type7
            • 189
            #260
            I use viper esc's with lipos. Since they were not meant to be used with lipos, they allow the battery to drain down to too low a voltage which affects the battery life. You can use a separate battery guard or don't run the sub as long.
            • The Boattrainman
              • Mar 2016
              • 443
              #261
              Thanks for the heads up, much appreciated.
              • The Boattrainman
                • Mar 2016
                • 443
                #262
                In order to make a stab at the hull markings, I'm using BECC vinyl Lettering (Cornwall Model Boats), they have sizes from 2 - 14mm, plus lifeboat signage, cargo ship warning signs, chequerplate flooring, miniature bezels, instrument clusters etc. etc. etc........
                I'm using this because Decals are the spawn of satan (for me at least), I can never get them right even using Decal Setter plus the carrier film always spoils the look. An alternative is Woodlands Scenics dry transfer (rub down lettering), but again I'm useless with the stuff.
                The kit decals are a useful aid and are stuck beside the location as a guide. Each 2mm letter is picked off the sheet and positioned, they have a sticky back which sets in 24 hours, but you can move them around to get them in line.
                Click image for larger version  Name:	IMG_1029 (800x600).jpg Views:	1 Size:	280.6 KB ID:	121431Click image for larger version  Name:	IMG_1027 (800x600).jpg Views:	1 Size:	261.6 KB ID:	121432
                Here is the name and the finished tail fin/rudder.
                Click image for larger version  Name:	IMG_1028 (800x600).jpg Views:	1 Size:	268.3 KB ID:	121433Click image for larger version  Name:	IMG_1032 (800x600).jpg Views:	1 Size:	273.8 KB ID:	121430
                So they are perfect? WRONG!
                They don't come in a range of Fonts (I think the Sculpin is close to Franklin Gothic 45 Degree), so if you are a stickler for detail, the larger sizes won't look right, but at 2mm I can't tell the difference.
                The Boattrainman
                  • 13573
                  #263
                  Originally posted by The Boattrainman
                  n order to make
                  Thisish
                  Laser-cut numbers!? .... where can I get this stuff at? Neat!
                  • The Boattrainman
                    • Mar 2016
                    • 443
                    #264
                    Sorry David,
                    You got in before I had the text uploaded. BECC as per above, they also do model cloth flags, pennants and come with excellent instructions.
                    Becc Model Accessories produce One of the largest ranges of decals flags and lettering for modelling use
                    • The Boattrainman
                      • Mar 2016
                      • 443
                      #265
                      And finally, two shots of the hull side depth markings, the BECC numbers are very crisp and give a very neat finish.
Name:	IMG_1033 (800x600).jpg
ID:	121447Click image for larger version
Name:	IMG_1034 (800x600).jpg
                      No carrier film around the numbers, no smudges, a coat of matt varnish and they will blend in well to the hull.
                      Two evenings work.
                      The Boatrainman
                      • The Boattrainman
                        • Mar 2016
                        • 443
                        #266
                        Here is the final electronic install, the Mtroniks 15Amp ESC for LIPOs that was recommended. This small fitting is made to hold the ESC switch.
Name:	IMG_1036 (800x600).jpg
ID:	121469Click image for larger version
Name:	IMG_1037 (800x600).jpg
                        The ESC sits on the small aluminium heat sink, and air can get around the unit.
Name:	IMG_1039 (800x600).jpg
                        The wiring is cut down to suit, it's BEC gives 1.2 Amps to the Receiver.
Name:	IMG_1040 (800x600).jpg
ID:	121472Click image for larger version
Name:	IMG_1041 (800x600).jpg
                        The Boattrainman
                        • The Boattrainman
                          • Mar 2016
                          • 443
                          #267
                          The final install of the rudders and dive planes takes place, here is the wiring of the rear rudder light.
                          Click image for larger version  Name:	IMG_1042 (800x600).jpg Views:	1 Size:	261.2 KB ID:	121486Click image for larger version  Name:	IMG_1043 (800x600).jpg Views:	1 Size:	282.0 KB ID:	121487
                          The install of the 5000Mah LIPO is below, it slides into the holder and is kept in place by the upper lip, a Deans plus is connected to shortened wires.
                          Click image for larger version  Name:	IMG_1044 (800x600).jpg Views:	1 Size:	248.8 KB ID:	121488Click image for larger version  Name:	IMG_1045 (800x600).jpg Views:	1 Size:	237.4 KB ID:	121489
                          There's just enough room for the 'battery to boat' lead and the LIPO balance plug when the end cap is installed.
                          Click image for larger version  Name:	IMG_1046 (800x600).jpg Views:	1 Size:	224.6 KB ID:	121490
                          The submerged trim is fixed not with round styrene tube, but square section. I used some Styrofoam attached to the outer hull to guesstimate the volume of tubing needed...........
                          Click image for larger version  Name:	IMG_1047 (800x600).jpg Views:	1 Size:	283.2 KB ID:	121491
                          ...........the square tubes are sealed at both ends.............
                          Click image for larger version  Name:	IMG_1050 (800x600).jpg Views:	1 Size:	257.8 KB ID:	121492
                          .........and the tubes are trial fitted up under the top hull, above the waterline so they don't affect the subs surface trim (the pencil lines indicate the outer limits of where the tubes will go).
                          Click image for larger version  Name:	IMG_1048 (800x600).jpg Views:	1 Size:	261.9 KB ID:	121493
                          No nasty closed cell flotation foam here!!!
                          The Boattrainman
                          • The Boattrainman
                            • Mar 2016
                            • 443
                            #268
                            The inner hull with the flotation tubes gets a coat of primer and varnish for protection.
Name:	IMG_1056 (600x800).jpg
                            Some excess wiring for the sail lights is left loose so I can get the sail off for maintenance.
Name:	IMG_1058 (800x600).jpg
ID:	121562Click image for larger version
Name:	IMG_1057 (800x600).jpg
                            One minor addition was to add a small bead on the end of the On/Off switch as the bare brass rod was scratching the hull on installation.
Name:	IMG_1055 (800x600).jpg
                            The Boattrainman
                            • The Boattrainman
                              • Mar 2016
                              • 443
                              #269
                              This build is effectively finished.
                              Other than putting the glass (plastic )in the sail there is not much remaining to do.
                              At the bow and stern points where the top hull mates with the bottom, I put on some very tough Yacht Varnish, as this is the area that will get nicks and dings, plus I'll smear some silicone grease along this shiny part as well.
                              Click image for larger version  Name:	IMG_1059 (800x600).jpg Views:	1 Size:	254.7 KB ID:	121573
                              Here are some final test tank shots of the boat in surface and submerged trim.
                              Click image for larger version  Name:	IMG_1060 (800x600).jpg Views:	1 Size:	231.9 KB ID:	121574Click image for larger version  Name:	IMG_1061 (800x600).jpg Views:	1 Size:	227.4 KB ID:	121575
                              The slight sacrifice to get the sub totally submerged (the last 2/3% of the Piston Tank) is that it has to surface run a fraction low in the water, a small compromise.
                              I'll post some shots of the sub on the shakedown mission in a few weeks, in the meantime, many thanks to everyone who gave useful tips, this was my first build log, and I would certainly do it again.
                              Rob (The Boattrainman)
                                • 13573
                                #270
                                Rob,
                                It was a joy following this WIP. Most comprehensive and instructive. Thank you very much for the time and effort it took to post this good stuff. Looking forward to video of this beast on and under the water.
