A Skipjack in Ireland
    Outstanding Captain!
  • The Boattrainman
    Update on the Skipjack, it's been six months since I've had a chance to take it on the water, due to our poor winter and concentrating on my U577.
    So I treated the sub to a spring clean up including......
    Click image for larger version  Name:	IMG_1634 (800x600).jpg Views:	1 Size:	280.5 KB ID:	125880
    ......replacing the tiny o-rings at the end of the prop shafts......
    Click image for larger version  Name:	IMG_1635 (800x600).jpg Views:	1 Size:	185.9 KB ID:	125881Click image for larger version  Name:	IMG_1636 (800x600).jpg Views:	1 Size:	254.1 KB ID:	125883
    .......... the threads in the plastic housing that takes the 2mm bolt that holds the two halves of the hull together were gone due to constant in/out, so I put in a 2mm brass rivet nut instead, plus I tidied up small nicks in the paint work.
    Off to my 2m deep canal!
    Here is the sub with, launch straps and equipment case ready to go.
    Click image for larger version  Name:	IMG_1633 (800x600).jpg Views:	1 Size:	355.3 KB ID:	125882
    And diving and manouvering well.
    Click image for larger version  Name:	IMG_1629 (800x600).jpg Views:	1 Size:	269.0 KB ID:	125884Click image for larger version  Name:	IMG_1631 (800x600).jpg Views:	1 Size:	364.3 KB ID:	125885
    I had changed the receiver settings as per David's recommendations (Pitch controller on the rear planes only), but there was something still way off.
    Then it hit me, major noob mistake! I had the Pitch controller the wrong way round, instead of lifting the bow when it nosed downwards, it was pitching it down further.
    To fix it, I had to move the Pitch controller........
    Click image for larger version  Name:	IMG_1637 (800x600).jpg Views:	1 Size:	302.7 KB ID:	125886
    .......luckily it works either mounted flat or on it's side, screwed to the side of the motor housing, it used to be under the pushrod on the left.
    That sorted out the smooth diving and surfacing.
    Click image for larger version  Name:	IMG_1625 (800x600).jpg Views:	1 Size:	338.6 KB ID:	125887Click image for larger version  Name:	IMG_1632 (800x600).jpg Views:	1 Size:	358.5 KB ID:	125888
    One final adjustment was I moved the throttle and rudder to the left stick, and the dive planes on the tower and the piston tank to the right stick.......
    Click image for larger version  Name:	IMG_1638 (800x600).jpg Views:	1 Size:	341.3 KB ID:	125889
    .......and the rear dive planes via the Pitch controller to channel 6, the round knob on the top right, as it's not sprung I can set the rear dive planes to perfectly level and never touch it again. I'm sure this set up breaks some time worn code, but I just couldn't get used to the dive functions split between left and right stick.
    Click image for larger version  Name:	IMG_1631 (800x600).jpg Views:	2 Size:	364.3 KB ID:	125890
    Click image for larger version  Name:	IMG_1625 (800x600).jpg Views:	2 Size:	338.6 KB ID:	125891Click image for larger version  Name:	IMG_1630 (800x600).jpg Views:	1 Size:	248.8 KB ID:	125892
    So some final thoughts.
    I had to dial the throttle function way down, this sucker really moves, and faster under water then on the surface for a given setting. Using the End Point Adjustment (EPA) on the Trans, they are now set to 50% for forward and 45% for reverse.
    The piston tank is very busy, it really sets the depth and the Pitch controller keeps it level, the planes on the conning tower are only used for fine adjustment.
    There is a 'sweet' spot, where the subs scopes are just below the water, any more ballast and it heads for the bottom, but once achieved, and the speed is kept under control, the tower planes come in to play.
    The single piston tank causes no problems, the sub dives clean and level, even at a stand still, blowing the full tank when at 2m depth sends sub screaming to the surface nose first, exciting but scary.
    It doesn't matter a jot where the extended receiver wire is positioned outside the WTC, I have it laid loosely along the side of the WTC and I got 2m of depth and 120m of distance (any more and I couldn't see the sub even on the surface). I had a hole in the base of the conning tower to push the wire up high, but it is not needed.
    I got 50 minutes of run time from the 5000mah Lipo, no idea how long it will last, a shower of rain ended the session.
    The endless sessions in the test tank (bath), messing about with ballast bars to get the sub perfectly level just under the surface have paid off.
    The Boattrainman
  • The Boattrainman
    Thanks guys.
    Putting some of the stuff I learned into the U-Boat 557 build, especially around the WTC which will have to be a semi-custom unit.
    I noticed given I had a stretch of open water that even with the 6.1 reduction gear box on the motor, this little sub really moves, had to dial down the values at the Transmitter to calm it down, quite hard to control at speed.
    Also, trying to access the 'dive' button (flooding the Piston Tank, which I have set up as proportional channel 5, a rotary switch on top of the Transmitter- top right in photo below) while holding the sub steady with left hand throttle and right hand rudder / dive planes, was tricky especially at even scale speed. I'm thinking of swopping the rudder to the left stick with the throttle, leaving my right hand a bit more free to tweak the 'dive' button.
    Good fun all the same!
    Beautiful, well done!
    Congratulations, sir!
  • The Boattrainman
    An update on the Skipjack in operation, here is the shakedown cruise at my local boat pond, which is a bit murky this time of year.
    Click image for larger version  Name:	IMG_1212 (800x600).jpg Views:	1 Size:	311.3 KB ID:	123179
    Sits well in the water.
    Click image for larger version  Name:	IMG_1213 (800x600).jpg Views:	1 Size:	248.1 KB ID:	123180
    And diving to one meter.........going......
    Click image for larger version  Name:	IMG_1214 (800x600).jpg Views:	1 Size:	283.0 KB ID:	123181
    ...........going.................
    Click image for larger version  Name:	IMG_1215 (800x600).jpg Views:	1 Size:	279.1 KB ID:	123182
    ....................gone.................
    Click image for larger version  Name:	IMG_1216 (800x600).jpg Views:	1 Size:	276.8 KB ID:	123183
    ..........and hovering just off the bottom!
    Click image for larger version  Name:	IMG_1217 (800x600).jpg Views:	1 Size:	235.8 KB ID:	123184
    The only mods I made was I installed three decent servos (Savox Digital Micros), and this stopped all glitching and twitching, but the sub required more trim tests in the bath.
    Everything is working as it should and so far the WTC is dry as a bone, I'll be heading to deeper water in a few weeks.
    The Boattrainman
    Originally posted by The Boattrainman
    It was great to have the banter with you, if you and the missus are ever in this part of the world drop me a message, I'd like to have a beer or two with you............!
    Thank you sir. And if you're over on this side of the dirt-ball, come on over and we'll stuff you with good Filipino chow.
  • The Boattrainman
    Rob,
    It was a joy following this WIP. Most comprehensive and instructive. Thank you very much for the time and effort it took to post this good stuff. Looking forward to video of this beast on and under the water.
  • The Boattrainman
    This build is effectively finished.
    Other than putting the glass (plastic )in the sail there is not much remaining to do.
    At the bow and stern points where the top hull mates with the bottom, I put on some very tough Yacht Varnish, as this is the area that will get nicks and dings, plus I'll smear some silicone grease along this shiny part as well.
    Click image for larger version  Name:	IMG_1059 (800x600).jpg Views:	1 Size:	254.7 KB ID:	121573
    Here are some final test tank shots of the boat in surface and submerged trim.
    Click image for larger version  Name:	IMG_1060 (800x600).jpg Views:	1 Size:	231.9 KB ID:	121574Click image for larger version  Name:	IMG_1061 (800x600).jpg Views:	1 Size:	227.4 KB ID:	121575
    The slight sacrifice to get the sub totally submerged (the last 2/3% of the Piston Tank) is that it has to surface run a fraction low in the water, a small compromise.
    I'll post some shots of the sub on the shakedown mission in a few weeks, in the meantime, many thanks to everyone who gave useful tips, this was my first build log, and I would certainly do it again.
    Rob (The Boattrainman)
  • The Boattrainman
    The inner hull with the flotation tubes gets a coat of primer and varnish for protection.
Name:	IMG_1056 (600x800).jpg
    Some excess wiring for the sail lights is left loose so I can get the sail off for maintenance.
Name:	IMG_1058 (800x600).jpg
ID:	121562Click image for larger version
Name:	IMG_1057 (800x600).jpg
    One minor addition was to add a small bead on the end of the On/Off switch as the bare brass rod was scratching the hull on installation.
Name:	IMG_1055 (800x600).jpg
    The Boattrainman
  • The Boattrainman
    The final install of the rudders and dive planes takes place, here is the wiring of the rear rudder light.
    Click image for larger version  Name:	IMG_1042 (800x600).jpg Views:	1 Size:	261.2 KB ID:	121486Click image for larger version  Name:	IMG_1043 (800x600).jpg Views:	1 Size:	282.0 KB ID:	121487
    The install of the 5000Mah LIPO is below, it slides into the holder and is kept in place by the upper lip, a Deans plus is connected to shortened wires.
    Click image for larger version  Name:	IMG_1044 (800x600).jpg Views:	1 Size:	248.8 KB ID:	121488Click image for larger version  Name:	IMG_1045 (800x600).jpg Views:	1 Size:	237.4 KB ID:	121489
    There's just enough room for the 'battery to boat' lead and the LIPO balance plug when the end cap is installed.
    Click image for larger version  Name:	IMG_1046 (800x600).jpg Views:	1 Size:	224.6 KB ID:	121490
    The submerged trim is fixed not with round styrene tube, but square section. I used some Styrofoam attached to the outer hull to guesstimate the volume of tubing needed...........
    Click image for larger version  Name:	IMG_1047 (800x600).jpg Views:	1 Size:	283.2 KB ID:	121491
    ...........the square tubes are sealed at both ends.............
    Click image for larger version  Name:	IMG_1050 (800x600).jpg Views:	1 Size:	257.8 KB ID:	121492
    .........and the tubes are trial fitted up under the top hull, above the waterline so they don't affect the subs surface trim (the pencil lines indicate the outer limits of where the tubes will go).
    Click image for larger version  Name:	IMG_1048 (800x600).jpg Views:	1 Size:	261.9 KB ID:	121493
    No nasty closed cell flotation foam here!!!
    The Boattrainman
  • The Boattrainman
    Here is the final electronic install, the Mtroniks 15Amp ESC for LIPOs that was recommended. This small fitting is made to hold the ESC switch.
Name:	IMG_1036 (800x600).jpg
ID:	121469Click image for larger version
Name:	IMG_1037 (800x600).jpg
    The ESC sits on the small aluminium heat sink, and air can get around the unit.
Name:	IMG_1039 (800x600).jpg
    The wiring is cut down to suit, it's BEC gives 1.2 Amps to the Receiver.
Name:	IMG_1040 (800x600).jpg
ID:	121472Click image for larger version
Name:	IMG_1041 (800x600).jpg
    The Boattrainman
  • The Boattrainman
    And finally, two shots of the hull side depth markings, the BECC numbers are very crisp and give a very neat finish.
Name:	IMG_1033 (800x600).jpg
ID:	121447Click image for larger version
Name:	IMG_1034 (800x600).jpg
    No carrier film around the numbers, no smudges, a coat of matt varnish and they will blend in well to the hull.
    Two evenings work.
    The Boatrainman
  • The Boattrainman
    Sorry David,
    You got in before I had the text uploaded. BECC as per above, they also do model cloth flags, pennants and come with excellent instructions.
    Becc Model Accessories produce One of the largest ranges of decals flags and lettering for modelling use
