3D Kick-Off!
    • 821
    Had I watched the video for that section I don't think I would have had the trouble I did. Live and learn. I knew what it needed to do but had trouble getting it to select the top surface of the bottom as the new sketch plane. Before I would have just done the math to create the circle at the right diameter to extrude the connecting flange but being able to dimension it from the outer edge is easier.
    • CC Clarke
      • Aug 2020
      • 313
      Model From a Drawing.pdf
      For all of you Fusion 3D lovers and wannabes, this tutorial is for you.
      Based on a YouTube link included in the file, I've added lots of figures and some additional explanations to help those who want to give this a shot the best chance to knock this one out quickly. The part being created is simple enough to build in an evening and provides a nice foundation for later challenges.
      Enjoy!
      CC
      As always, if you find something that could use fine-tuning or a better way of explaining, feel free to provide constructive feedback.
        • 821
        Yay! Another challenge. Thank you. I have actually used some of what I learned in the last one.
        • SamStaton
          • Feb 2022
          • 1
          Excellent! This is something I have been looking for!
            • 821
            My dang computer it giving me a fit right now....getting it sorted out. Hopefully I can get to this latest lesson soon.
            • Occupant
              • Jan 2025
              • 40
              Not sure if this fits here but what the hell.... I've been CAD jockey all my career (now retired) and to see the advances and what can be done on a laptop is just amazing. Just out of high school was hired on as a Frankenstein (what i was told) someone with no prior experience to see what would happen. At the time we used Computervision CADDS 4X - wireframe tool. basically like working a 2D board. after a bit they introduced 3D but still wireframe. you could spin the model but to get a realistic image you'd manually trim out / erase the hidden lines which was a very labor extensive process. The computer was a mainframe with large magnetic platter packs. to reboot the computer it was manually setting addresses - load, new value load next, blah blah blah then run. the systems were't stable and crashed at everything - vacuum cleaner in the room? Training was comical at times - teach me what layer is without using the word layer! The company i worked for tried developing their own, it was an odd duck with command structures being numerical. Insert line horizontal was a string of numbers to call the command, like memorizing a bunch of long distance numbers to get your work done efficiently. We (designers working the evaluation) got it killed by proving it produced mathematical errors in modeling. switched gears slightly a couple years in going from an aerospace company to an architects office while in college. Worked on several projects in the Orlando FL area.
              Next CAD tool was Intergraph (married, moved to GA) worked at a small architects office where they had one seat of software and had ****ed off the operator and he quit. I was able to read the manual and teach myself the software in a week. I finished their first job done on the computer (Nigerian national mosque), as a reward got sent to an Intergraph convention in Huntsville Alabama and saw some of the stuff they were doing. Intergraph was primarily meant for cartography and they had a hardware setup they showed me that was cool - looked like a microscope - one eyepiece was the CAD model, the other showed the map you were working on using your head as the mixer, bizarre but cool. From there moved back home and learned yet another CAD tool Proe - later called Creo. This was my first foray into true solid modeling. Prior to this we had engineers that did nothing but mass properties - how much does this weigh? Now its push a couple buttons and whoala! On top of that hidden line removal, shaded images - whoa... add powerpoint and design reviews are on a new level. A few years ago they talked about about breaking off the business area i was in and asked me to look at tools, what CAD tool would we use, how much would it cost? We were using Creo at the time, i'd tried some other programs, Fusion 360 seemed so ass backwards i gave up trying. I was able to get a trial copy of Solidworks to try. I used a manifold part as a guide, created in Creo and timed it, then i did the same in Solidworks ( with zero training) Solidworks took just a bit longer figuring out where things are an not having mapkeys - macro shortcuts for string of events. Even with that recommended Solidworks for simpler more forgiving user interface, cost, etc. My point - none, pick something and start playing with it like you do with play doh, extrude some then what you want to do - look for commands that sound like what you want to do have fun.
                • 828
                Raising hand to instructor. Can the DSRV files above print with resin too? Or just FDM? Or both?
                  • 2564
                  The problem I find with all CAD and using computers in general is that it’s very much a left brain activity, as opposed to practical crafting which is largely a right brain activity.
                  It’s a good tool for getting an idea tidied up for production, but I always find it tough to freestyle on such programs. I still favour a chunk of wood and a spokeshave.
                    • 13858
                    Dinosaur!!!!
                      • 2020
                      I find the opposite. In CAD, I can iterate a dozen ways faster than doing one physically. I can create all of those iterations quickly, choose to prototype all of them with a click of the button, and then choose which works best.
                      Commit to a physical part.. what if you need to make one tiny adjustment? You're redoing the entire thing. In CAD, a few clicks and you're done.
                      I get the left/right brain thing, but in our hobby, the machines still can't do all the work. It still requires assembly, finishing, trimming and more.
                        • 2564
                        If you already know what it is you want to do, so you have it in your head or you’ve made a some doodles on a pad it’s certainly a useful tool.
                        Everyone is different, what I will say although cad is very powerful I find more satisfaction in hand crafting items where appropriate.
                          • Jan 2020
                          • 1028
                          totally agree Bob
                          • Occupant
                            • Jan 2025
                            • 40
                            Along with CAD comes methods, 3D printing, scanning, allowing us to fabricate some pretty wild things not easily produced via hand crafting. You use WTC Water Tight Cylinders where I'm creating a Water Tight Container printing in clear resin, (can see power indicator thru it). Nothing but respect for all the hand crafters out there, so many tips and tricks to learn from them.
ID:	192710 Click image for larger version
                            • CC Clarke
                              • Aug 2020
                              • 313
                              Resin 3D printing is highly recommended, though it gets expensive for a bottle of the super-hard, engineering resins over an ABS-like resin, which is at least 1/3 the cost. 3D resin printers have far more thinner layers (higher resolution) for very smooth exterior surfaces, which is a game-changer in sanding reduction. There's a price to pay for this enhanced detail with a messy, post-printing cleaning and curing processes requiring a dedicated work area.
                              Another big difference with print quality is how well the DSRV files are oriented and sliced using your preferred slicer for best results. You could consider using cheaper resins to get the most efficient orientation that minimizes banding, before locking down your print settings and going for the expensive stuff for your final field or display version, depending on application.
Name:	Shock Mitigation System Component Comparo.jpg
                                • 828
                                #30
                                Thank you. I use a Any Cubic 3D Max already (seen in these forums in my Suffren thread). I had a hard time learning curve in beginning, but now I use without difficulty.
                                Glad the STL files provided also will print resin too. Yes indeed. the "3D resin printers have far more thinner layers (higher resolution) for very smooth exterior surfaces, which is a game-changer in sanding reduction". Very happy with its performance now. Very high resolution and can accommodate printing large parts.
                                It has to be operated in a room with 70 degrees F minimum temp. So, if in a garage, it's too cold to operate in winter even here in California. The other issue is any dive module or WTC made- the resin is still too porous. Fine for the free flooding parts. The parts would be turned on a lathe with McMaster Carr PVC bulkheads and Lexan tubing.
