Can an active variable ballast system like a water pump or piston be used for changing depth in lieu of dynamic surfaces ( dive planes)? Guess you'll still need active pitch control for any longitudinal instability.
Can the KMC Depth Cruiser be used to control such variable ballast system? Using an ESC controlled pump instead of a servo controlled dive planes.
