Variable Ballast Tank
    • 3497
    Can an active variable ballast system like a water pump or piston be used for changing depth in lieu of dynamic surfaces ( dive planes)? Guess you'll still need active pitch control for any longitudinal instability.
    Can the KMC Depth Cruiser be used to control such variable ballast system? Using an ESC controlled pump instead of a servo controlled dive planes.
    • 3497
    This is for those early submarines that lack proper dive planes or had anemic ones.
    Icteneo II
Name:	images (1) (7).jpg
ID:	166844 https://www.lowtechmagazine.com/2008...marines-1.html
      • 1936
      Romel,
      My observation! I think yes that a ballast system could be used in the place of dive planes! If the boat was weighted properly and with 2 ballast systems one more towards the bow and one to the stern and were independent of each other as to operation, and then speed would have to be involved to a certain degree as well.
      I would sure like to have some STL files on that sub!!
        • 3497
        Click image for larger version  Name:	print-and-build-your-own-model-kit-of-the-ictineo-ii-3d-model-bf74732b6a.jpg Views:	0 Size:	70.3 KB ID:	166848
        found this
        Meant to be a static cut away model with one side open to show interior. Maybe it would be possible to play around with the files to print a mirror image of the starboard side to make a full hull. Click image for larger version  Name:	print-and-build-your-own-model-kit-of-the-ictineo-ii-3d-model-8ec27d1a57.jpg Views:	0 Size:	49.2 KB ID:	166847
          • 3497
          • vital.spark
            • May 2010
            • 307
            I was able to see both I & II in Barcelona. The technoligy in II was and still is mind blowing!!
              • 3497
              STL file available https://www.cgtrader.com/3d-print-mo...the-ictineo-ii
              • SubICman
                • Jun 2022
                • 87
                Most slicers will allow you to mirror a part on the plate
                  • 3497
                  Going back to my first question, using a variable ballast tank instead of dive planes to change depth - see video.
                  Just leaves the 2nd question.
                  Can the depth cruiser control a variable ballast system?
                    • 873
                    I would imagine it all depends on how many amps are required to change the displacement. A simple vent and blow, I'd say sure -but a screw jack system would need a go between relay or servo (operative words are " I would Imagine")...BG
                    • QuarterMaster
                      • Sep 2015
                      • 1237
                      Icteneo II
                      Wow Rob, love it! It has "Steampunk" written all over it! This would have fit right in as a Sub in the old, graphic adventure/puzzle video game, "Myst".
                      Very cool.
                      v/r "Sub" Ed
                      • QuarterMaster
                        • Sep 2015
                        • 1237
                        ....and to the question? Why not? I'm always the first to say build to your requirements, not just to an idea. Here you are presented with a perfect example! People make some wonderful things happen!
                        v/r "Sub" Ed
                          • 998
                          There actually was a sub on rails in myst III-exile.
                          Loved those games, until they had a 3d-environment...
                            • 1936
                            found this
                            Thanks for the info Romel!
                            I did see this on CGtrader, and can now see a possible way to print a submarine here! I could print two halves to go together to form up a complete hull! WOW! Yes, this would work! I think it would be worth the $98.00 to get these files. I would not only attempt to build a full operational submarine, but also build the kit as designed as a model.
                            WOW! Here we go! Thanks again Romel!
                              • 1936
                              Ed,
                              In some respects, you and I really think alike! You like stepping outside the box with your building subs and for sure when it comes to the radio systems that you have set up. I can really feel a cool build here!
