Variable Ballast Tank
  • QuarterMaster
    • Sep 2015
    • 1244
    Originally posted by rwtdiver
    I can really feel a cool build here!
    Agreed! It has a need (no pitch physical dive plane control), so you're given a requirement. Require some form of depth and/or pitch control w/o the addition of stern planes to make it authentic to the prototype.
    Now some of us, myself included, may elect to solve the requirement by forgoing exactly duplicating the prototype, by the use of clear stern planes. Ray Mason uses clear bow planes on his Disney NAUTILUS and rear fixed clear vanes to keep it level. As possibly the first operation Disney NAUTILUS, it was his solution to a requirement to even dive while maintaining a semblance of depth control.
    Bob Martin met this requirement by conceiving and using a pitch propeller shaft to maintain pitch control.
    BOTH solutions meet the requirement, yet aren't "true" to the design intent of Mr. Goff. (Purist rivet counters may now fling arrows at the semi scale lowlifes)
    You can chose one the two above, or select a different solution. Still meeting the requirement.
    Too be honest, I would go with simple gas ballast, and steal Bob's pitch prop as the simpler (to build, test, operate), but that's me and follows my build philosophy.
    Funny enough, I really am a keep it simple stupid guy, while trying to enjoy the latest tech. Just enough to get the job done, reliably and consistently.
    Unlike Capt. Frank Salerno and the ever evolving SSRN SEAVIEW. By the time he's done adding features he'll be able to make love to it.​
    v/r "Sub" Ed
      The original boat used shifting weights on a threaded rod for pitch control.
        I see no reason that a DC couldn't control the ballast system, but not directly. It simply creates servo signal to command a module, be that a servo, an ESC or a relay.
        Too many people get caught up with the labels. These devices take inputs and provide outputs. Utilization is completely open. Break it down into what the unit is actually doing, then think through what it puts out and how that can be used.
          • 13988
          Credit, where credit is due, Ed:
          https://youtu.be/kOO_sz6Sh7U​
          https://youtu.be/cwS6o4jsxoU​
          • QuarterMaster
            • Sep 2015
            • 1244
            I ALWAYS do Dave, when I know it. More so than others.
            Perhaps I should start those unknown claims with, "I believe it was..."
            And YOU know I've have mentioned you enough times we might as well get a room together.
            v/r "Sub" Ed
              • QuarterMaster
                • Sep 2015
                • 1244
                I f***ing LOVE Bender!!!
                v/r "Sub" Ed
                • cheapsub
                  • 193
                  What about the one Dave build some time ago.
                  Civil War submarine alligator.
                  May be a steampunk version II.
