Russian Alfa Class
  • SubDude
    • 825
    #121
    Looking good Rob. Following along.
      Thanks Steve,
      I am really looking forward to building this Alfa out to the fullest extent that I can. A WTC with a proper working ballast system, functioning diving plains, rudder, and propulsion system. And when that has been achieved, a properly finished out David M. hull!
      • neitosub
        • Nov 2021
        • 163
        #123
        Always loved the Alfa class, 1/72 is a bit too big for my liking but 1/96 scale is perfect.
          NEITOSUB,
          My Alfa build is not a true 1:72. I purchased the files from Nautilus Drydocks (1:96 scale) and modified the size of the files to get as much additional length to my build as possible using my DREMEL 40 3D printer. 170mm is my max height on this machine. I took Bob Martins files and I am building at 125% which is a little smaller than 1:72 scale, not sure what the scale is! I am scratch building my WTC system for my boat, and will need the extra length.
          • neitosub
            • Nov 2021
            • 163
            #125
            That is a great advantage of 3D printing programs, you can rescale a boat very easily!
            Nate
              I have the bottom sections of the Alfa hull completed!
Name:	Alfa WTC 2.jpg
ID:	156970Click image for larger version
Name:	Alfa WTC 3.jpg
Name:	Alfa WTC 1.jpg
              I also purchased two 24" cylinders (one 3.00" and one 3.50") Not totally sure which one I will use just yet. I have the 3.50" cylinder in the two photos above. Until I get the top hull sections complete, the cylinder selection is up in the air at this point.
                • 13976
                #127
                Go with the 3-inch. You'll appreciate the extra annualar space when it comes time to trim that bad-boy.
                Click image for larger version  Name:	DSCN0102.JPG Views:	0 Size:	95.6 KB ID:	156974Click image for larger version  Name:	IMG_0619.JPG Views:	0 Size:	53.3 KB ID:	156975Click image for larger version  Name:	IMG_0613.JPG Views:	0 Size:	50.4 KB ID:	156976
                  Hi David,
                  Thats what I was thinking, plus the extra length will give me more room for the electronics and the ballast system.
                  • Monahan Steam Models
                    • 755
                    #129
                    Looking good Rob! Happy to see you back at the submarine projects.
                      Thank you, Nick!
                      I really do enjoy building submarines, I do like the challenges involved. I will finish up the Utility Boat that I started, but as a break-away project.
Name:	Alfa Bow 1.jpg
                      I took the above photo of the Alfa Bow, just to show how much detail is coming through on the 3D printed files. The detail on this entire boat is one of the best that I have built from Nautilus Drydocks files!
                        Today I finished up the upper and lower hull sections on the Alfa! The completed sections took a total of 158 hours print time
Name:	Alfa Sections Complete 1.jpg
ID:	157095Click image for larger version
Name:	Alfa Sections Complete 2.jpg
Name:	Alfa Sections Complete 3.jpg
                        The only items left to print out are the controls surfaces. (Upper and lower rudders, forward dive planes, and the stern dive planes)
                        After the printing process is complete and I have all the parts, I will put my attention to the stern section control linkage systems.
                          A little more update on the progress of the Russian Alfa.
Name:	Alfa Top Section 1.jpg
ID:	157184Click image for larger version
Name:	Alfa Top Section 2.jpg
Name:	Alfa Top Sections 3.jpg
                          I still have a little more section edge sanding to true up section joints before gluing. As I have stated before, the print files on this Alfa are excellent. Very little tune up on the section line ups!
                            Detting ready to start putting the Alfa together.
Name:	Alfa Glue-Up 1.jpg
ID:	157216Click image for larger version
Name:	Alfa Glue-Up 2.jpg
                            I have the gluing table prepared and covered with saran wrap so the parts will not stick to the gluing board. I also have the Alfa 1/72 that I have already built in the background to be used as reference if needed!
                            • SubDude
                              • 825
                              #134
                              Looking good Rob.
                                Looking good Rob.
                                Thanks Steve,
                                I am hoping to get both upper and lower hull sections glued up tomorrow. Providing I do not get to many "Honey Do's" getting ready for Christmas! :-((
