Russian Alfa Class
    • 1628
    #166
    As secretive as the Rooskies are, they don’t mind you seeing their subs. Especially the power plant and propeller.
      • 13909
      #167
      But, when they were new, the Commies went to great lengths to keep these boats under wrap. Only recently, well after these boats were pulled from service, has good dope on their physical characteristics crept into the hands of the general public.
        • 1628
        #168
        I think I’m going to buy this. Not. I’ve seen this POS before.
        https://www.ebay.com/itm/11516146399...EAAOSwLSdhpBOw
          • 13909
          #169
          I got a bridge you can buy...
            • 1628
            #170
            He’s tried to sell this wooden POS on RC Groups. Con artist.
            • James Wittaker
              • Oct 2021
              • 67
              #171
              Really miss your Alfa sub 6 tube launcher,Sir! Which submarines you would armed with teeth?
                • 13909
                #172
                1/72 Revell Type-9; 1/72 Revell GATO; 1/72 THRESHER; 1/96 SKIPJACK; 1/72 SKIPJACK...
                  Originally posted by rwtdiver
                  Normally I would not show off my screw ups! But sometimes lessons learned the hard way should be shared so others do not make the same costly mistakes.
                  Click image for larger version  Name:	Bad Stern 1.jpg Views:	33 Size:	80.5 KB ID:	158893
                  Click image for larger version  Name:	Bad Stern 2.jpg Views:	30 Size:	72.4 KB ID:	158894
                  Here is what happened! After hours of prep work installing the bushings in my 3D printed Alfa stern, and then manufacturing the linkage horns on rudders (2) and the dive planes (2) and installing them for the final hook up. I used a very common approach to installing the control surfaces to the linkage rods. Boring a small hole in the control surface and then using thin CA to secure the control surfaces to the linkage shaft.
                  laying the control surface flat and then putting in one drop of thin CA into the prepared hole. I used a kicker to speed up the process, and thinking the CA had cured, which it did on the surface I pick up the project and went to a vertical position to make sure I had movement! Guess what happened!? Even though the CA had cured at the hole I still had liquid CA on the inside of the shaft that immediately ran down the shaft and into the bushing. Stupid mistake on my part! Well needless to say the control shafts where now glued to the bushings.
                  Lesson Here: Do not move the control surfaces until you are sure that the CA HAS CURED>
                  I now have to re-print a new stern section and four control surfaces and start this portion of my build all over again. I hope my lesson will help someone that is using this process on their build.
                  Geez you guys!
                  And I am still trying to get a 1:96 Alfa stern section to come together! Talk about an inferiority complex! WOW! I can't even get a set of rudders or dive planes operational! There just is not enough time in life left to do what you masters do!!
                  "I WILL CARRY ON"
                    • 13909
                    #174
                    Stop whining and get back to work, Fireman!
                      Ramel,
                      That is certainly a viable solution to the problem, and I thank you for that.
                      Click image for larger version  Name:	NEW STERN.jpg Views:	23 Size:	72.1 KB ID:	158908
                      I just remembered a note from the not distant past from our MASTER David M. The use of Vaseline on the shaft ends and inside the brass bushing. I guess it's my time in life to start using a legal pad and writing this stuff down, it sure would have saved me a time costly situation here.
                      Third time has to be the charm!! We move on and never give up in this hobby till we get it and get it right!!
                      New stern on it's way! Thank God for 3D Printers!!
                      • James Wittaker
                        • Oct 2021
                        • 67
                        #176
                        Amazing work! I mean …your next project, sir . Which sub will you add Torpedo launching system?
                          • 13909
                          #177
                          We're cluttering up Ron's thread. Recommend you start another thread.
                            • 2028
                            #178
                            Rob (et all),
                            Since the part is pooched anyway if it doesn't succeed, something you can try is to heat up the linkage shaft to cook off the CA inside. Now, if you don't have a convenient chunk of shaft free to get the tip of a flame on, this can be problematic. I've tried with some success at various points in my career, to use the tip of a soldering iron on the end of the shaft. PLA will soften up a lot faster than the resin parts that I historically tried this on, so no guarantees, but as I said.... the parts are trash anyway. No harm in trying next time!
                              Originally posted by SubHuman
                              Rob (et all),
                              Some good ideas here! Thanks Bob and to every else that has chammied in. That's the great thing about 3D Printing in my case, you screw up (which is a process for me) you just download the part to the printer, move on to doing something else while the machine dose the work. and in a few hours, you have another new part to sacrifice (if need be)
                              AND DAVID! Your work is ALWAYS WELCOME SIR!!!! And stop calling me Ron!! You're giving me a complex!! :-))
                                • 13909
                                #180
                                Oh, ****! Sorry, Ron. I did it again! Damn! I don't know where this 'Rob' stuff keeps coming up. My apologies, sir.
                                (The brain is the second thing to go)
