Russian Borei Sub Build
    Go with 'B'.
    'A' has way too much pitch.
    Thanks David!
    "B" it is! Moving on to complete the stern of this boat and finish up the rest, like the sail, and bow planes!
      Originally posted by Davidh
      Hello Rob,
      She is a nice boat but sluggish to turn.
Name:	nice blue borei.jpg
      Dave,
      Dave,
      I am assuming the photos are of the Borei 955 and not the 955 ll?
        I have started to work on the sail (conning tower) appendages (periscope, radar, etc..)
ID:	151143Click image for larger version
        I am going to use mostly brass tubing and Apoxie Sculpt to achieve the desired look! (as close to the original as possible)
          • 13971
          #49
          Why brass when aluminum (the right 'color' and light of weight) is a better choice for the masts?
ID:	151148Click image for larger version
ID:	151149Click image for larger version
            Your wish is my command ,aster!!
            On it's way! Nothing more that I enjoy doing! Than doing everything over 2 or 3 times!!! :-))
              • 13971
              #51
              Good show, sir!
              • RanSan
                • May 2020
                • 70
                #52
                Coming late to the party. Here is a great thread on the Borei that has some answers to your jet pump impeller quesiton. I wish I had found it when I was origanally drawing the 3D files. Also if you are a sub committee member David has an article in SCR 11 titled "Model submarine propeller theory, design and fabrication".
                Hello All, After completing the re-tooling of the Resolution a couple of months ago, I have had the idea to embark on yet another boat. I can't help myself.
                Randy
                  I've long had a glass reinforced plastic/fiberglass (GRP), resin and white-metal Precision Pattern (http://www.precisionpattern.biz/subs/index.htm) 1/96
                    Randy
                    Randy,
                    Thank you very much for posting the build blog on the Borei! It is extremely helpful not only with the impeller, but with other building aspects. The sail was another area which was covered as well!
                    Thank you for sharing that build blog with us!
                      Romel,
                      Thank you for posting up that great information! Between David M., Randy and you I have a lot of information on impeller construction!!
                      Thank you!
                      'Firemen can stand the heat"
                        Worked on the Borei sail today!
ID:	151164Click image for larger version
                        I have a good start on the sails array of different antennas! I picked four of the most dominate antennas that I found on some original photos and went with those!
                        I stayed with the original BRASS tubing, because that is what I started with, plus I have a lot of hand work done to get them to this point. I realize the photos show a sort of dirty alum. color, and I will be able to get that effect with paints. These are not complete yet, because I still have little tidbits to add to them, and also the final sanding and clean up work prior to adding the detail painting!
                          • 13971
                          #57
                          Pickle the brass so it does not shrug off the primer-paint later.
                            I sure will do that David! Thanks for the reminder. I ordered the material (acid) that I will be using on the Type ll that I am building, and I will use it on any painted brass on my Borei!
                              Temporally bored the holes and mounted the sail arrays just for fit!
                              Click image for larger version  Name:	P1010000.jpg Views:	0 Size:	51.2 KB ID:	151197Click image for larger version  Name:	P1033333.jpg Views:	0 Size:	48.3 KB ID:	151198
                              They will be mounted after the sail is secured to the hull and basically finished!
                              Before anyone jumps in please note they are not finished yet!!!
                                Today I finished up the sail and mounted it to the hull!
ID:	151227Click image for larger version
                                The above photo shows the underside of the sail, and the bottom support holes for the sails antennas! This will allow me to completely finish the sub hull inside and out, and then install the antennas through the top and down through the support holes (which line up perfectly) secure them and we are done with this build!
                                What's next will be the prep work and final finish work! Time to start the next 3D printing project! The Russian Typhoon!
