Russian Borei Sub Build
    Recently I purchased the 3D print files for the "Russian Borei" from Nautilus Drydocks! My intentions are to use one of the WTC ((SD) that I have built for some of my other subs! This will be a static model, as well as a surface runner with the possibility of being able to dynamic dive in my pool!
    I will most likely put my ANYCUBIC Predator to work on this project! I will be using Solutech white PLA and fabricate it at 100% infill! I will start posting the build with photos
  • Davidh
    • Nov 2010
    • 719
    Hello Rob,
    She is a nice boat but sluggish to turn.
Name:	nice blue borei.jpg
    Dave,
    • QuarterMaster
      • Sep 2015
      • 1244
      Awesome Rob!
      Scale?
      Ed
      v/r "Sub" Ed
        Awesome Rob!
        Scale?
        Ed
        Hi Ed,
        Thanks, Another learning project for me!
        This Borei is a 1:144 scale that I am 3D printing from files that I purchased from Nautilus Drydocks.
        It seems like every time I turn around, Bob puts up more print files that I just have to have! I believe this hobby has turned into a sickness for me Ed!!
        My wife said I may need "some professional" help!
          The mighty "Predator" has begun it's work on the Borei!
ID:	149179Click image for larger version
          • QuarterMaster
            • Sep 2015
            • 1244
            1:144?
            Darn it, was hoping we could chase 1:96 Boomers around the Pond.
            Looking good.
            Yes, addicting.
            Yes, we need help. (All Admirals will agree on that!!)
            v/r "Sub" Ed
              • Jan 2020
              • 1036
              Stupid question? Do the files include the wtc cradles and necessary fittings?, or does one need to fabricate them?
                Hi Bruce,
                The Borei files do come with cradles as such, but it has what is called rings, and I am assuming they are the cradles, not as beefy as most cradles are! Not sure what you mean by fittings? It's a basic hull with rudders, dive planes, and sail!
                  Hi again Bruce,
                  Here are the photos of the lower hull cradles (or rings) for the Borei! It looks like the upper cradles are the same! Hope this helps you!
                  There are four for the upper hull, and four for the lower hull!
                    • Jan 2020
                    • 1036
                    Thanks Rob! When I said fittings I meant like pushrod connectors, rudder arms, and bow and stern arm files
                      • Jan 2020
                      • 1036
                      I guess I am referring to the rudder, dive planes and stern plane yokes?
                        Bruce
                        The items you have listed you will have to fabricate!
                          Originally posted by Davidh
                          Hello Rob,
                          Dave,
                          Dave,
                          I missed your input information and photos of the Borei!? Thank you very much for posting! I assume the photos are of your Boat? None the less it sure looks great in the water!
                          • Davidh
                            • Nov 2010
                            • 719
                            Hi Rob,
                            Yes, this is my Borei kit that has been on the market for a couple of years now. She is a nice boat however being a Russian Boomer she has a small rudder area and isn't so great at turning.
                            Nice and big hull, plenty of room for everything.
                            Dave H
                              Update on the Borei! I have all the parts printed out!
ID:	149594Click image for larger version
                              I need to do some clean up work on the parts, and then it's ready to start putting it together! I am very pleased as to how well the parts printed out!
