today's work
    • Oct 2017
    • 1097
    #3841
    ...freddy says "under pressure"...
    • NavyShooter
      • Jul 2026
      • 45
      #3842
      Ok, wow! So you do the pours with the brass inserts in place already? Gets a perfect seal that way?
        • 13971
        #3843
        Those 'inserts' are temporary: they suspend the soon to be encapsulated O-ring before pouring resin. Once the casting has changed state from liquid to solid the part is extracted from the tool, the 'insert is removed, leaving the O-ring to do its job of making watertight ether an axial running pushrod, or making water tight the union between bulkhead and conduit.
          • 13971
          #3844
            • 13971
            #3845
            • NavyShooter
              • Jul 2026
              • 45
              #3846
              Since I'm mostly a 'skimmer' guy, I'm also working on scaling up a 1/1000 version of the Halifax Class Frigate to 1/144 to make it R/C suitable.
              See how it goes. I've got a sample print going right now.
                • 2637
                #3847
                It’s a dinky little boat that one, Dave.
                  • 13971
                  #3848
                  • Timothy L
                    • Sep 2024
                    • 246
                    #3849
                    I’m not following. What is the Arm & Hammer used to accomplish? Thank you.
                    Tim
                      • 13971
                      #3850
                      Tim
                      Click image for larger version  Name:	IMG_8479.jpg Views:	0 Size:	83.8 KB ID:	198133
                      To make a quick and dirty filler you first apply wet CA to the area you want to fill. You then sprinkle on backing soda, (Sodium bicarbonate) over the goo. The high pH of that compound is very high, causing the CA to cure hard almost immediately. You then grind away the excess with rotary tools, files, and sanding sticks.
                      Like so:
                      • Timothy L
                        • Sep 2024
                        • 246
                        #3851
                        Thank you. Holy crap!!!!
